Need parts info. Engine Oil Cooler Radiator fitting
Old Dec 21, 2023 | 11:21 PM
S Reynold Gudam's Avatar
Default Need parts info. Engine Oil Cooler Radiator fitting
Mine developed a leak from the fitting at the radiator side. Mechanic told me damage to the O Ring inside radiator causing the leak and I have to change to complete brand new radiator. I have a doubt just for a small leak I need to change a whole radiator? I seek any advice from you guys. Thnks in advance...
Old Dec 22, 2023 | 11:37 AM
legerwn's Avatar
The fitting is a common item that can be purchased from most of the local parts houses, search for Oil Cooler line connector,
The O-ring is a little more challenging to locate and needs to be the correct one to seal correctly,
A new fitting price ranges from $6 to $20
If its leaking form the the internal oil cooler seal then they are correct, a new radiator will need to be purchased, the oil cooler is installed prior to the radiator tub being installed
Neal
H32006
Dec 28, 2021 09:43 AM
MarkMc00
Aug 25, 2020 05:17 AM
Admiral_3vn
Apr 12, 2015 09:47 AM
Ghost Rider
May 29, 2013 11:57 AM
gangstagirl
May 5, 2007 06:14 AM
