Need help bleeding brakes after new lines and master cylinder
Not if you are using the hacked Tech2Win software, must also have the correct "card" image configured for Tech2Win to run in order to have the vehicle selections, etc. I forget how but it is a bit fiddly to get it configured and then it needs an MDI or compatible J2534 serial interface to connect between the computer and the vehicle.
I must have the ****tiest luck and i refuse to give in! hehe. I got my Tech2win working and it starts the auto bleed and it keeps crashing at random times. Once was when i opened up the first bleeder, then the 2nd...I got as far as the 3rd (rear right). Now my brakes are really soft again. Worse than when i started today, so i guess my air vacuum brake bleeder did something right a few days ago, just not enough.
anyone else experience tech2win crashing?
Also when you start the process it says, ignition on but engine off, hold brake steady and hit continue. When you hit start it says open front left bleeder screw and pump brakes continuously. What happened to holding the brakes steady? Then after the abs pumps a few times, it says STOP, Release brake. So which is it, do we hold brake stead or keep on brake, release until it says stop?
Not helpful with your foot on the pedal. Need a measurement with pedal in normal position, no foot required!
i must have the ****tiest luck and i refuse to give in! Hehe. I got my tech2win working and it starts the auto bleed and it keeps crashing at random times. Once was when i opened up the first bleeder, then the 2nd...i got as far as the 3rd (rear right). Now my brakes are really soft again. Worse than when i started today, so i guess my air vacuum brake bleeder did something right a few days ago, just not enough.
Anyone else experience tech2win crashing?
Also when you start the process it says, ignition on but engine off, hold brake steady and hit continue. When you hit start it says open front left bleeder screw and pump brakes continuously. What happened to holding the brakes steady? Then after the abs pumps a few times, it says stop, release brake. So which is it, do we hold brake stead or keep on brake, release until it says stop?
Pedal travel variance! I don't know the length of the rod to your master? Simple to calculate upward/lowered position on the pedal, to see if there is too much travel.
