Most common problems with H2's
Old Apr 16, 2010 | 10:12 PM
  #31
atashashane's Avatar
Originally Posted by VegasGuy
That's a pretty inclusive list Boss. It would be helpful if other members could pitch in and let prospective Hummer owners know which years are affected. For example, the mirror folding problem only affects 2003 to 2005. I know the wiper issue was fixed, but I am not sure of the year. 2005?
I do not recall the fuel pump being a common problem. And what is #6? Can't find the wiper motor?
I would also add that the air bag suspension seems to come up on this forum with some regularity.
are you sure fuel pump is the culprit with your ride?? nothing else as per your service advisor. just let me know of any developments.
Old Apr 24, 2010 | 11:36 AM
  #32
TerrySW's Avatar
Default My Problems
Windshield washer pump comes on by itself some times but only when its raining. I assume water is getting in some where. I have a vibration at low speed can not feel it, just hear it. Replaced the fuel cap and still get an error message that says tighten fuel cap. That's my list folks.
She rocks!
Old Apr 24, 2010 | 02:41 PM
  #33
VegasGuy's Avatar
Do a search on this site and you will find it was a factory defect that is covered by a recall. My H2 is fine, but others say they got it fixed at no cost to them.
Old Apr 24, 2010 | 05:07 PM
  #34
TerrySW's Avatar
Default Thanks
Thank you VegasGuy. Will check it out for sure.
Old May 1, 2010 | 10:08 AM
  #35
KenCoollest's Avatar
Ohly problem so far is lighters not working I replace R44 fuse but they still don't work
I'm going to take it to the dealer, hope its covered under warranty.
Old Apr 15, 2011 | 11:38 PM
  #36
jlouderb's Avatar
Default Cover for windshield wiper motor
Took the 98k Hummer to the dealer for some service today - they saw the windshield wiper cover problem as a recall and replaced it. Alas, the motor itself was bad too, which meant I paid for that. But the recall works no matter the year! Get it fixed.
jim
Old Apr 19, 2011 | 10:32 PM
  #37
Brianb's Avatar
2006 H2 63000 miles:
Replaced Starter about 55k
Just Replaced:
Idler Arm
Pitman Arm
Wheel Bearings
Power Steering pump
At 63K. But it was all under waranty luckily.
Just an FYI
Old Apr 20, 2011 | 01:46 PM
  #38
parabat's Avatar
Hello.
I've had the main bearing on the front diff go twice now. I was told by my local shop that this is a common defect on the H-2 and other large SUV's
Old Apr 21, 2011 | 04:36 AM
  #39
madmike's Avatar
Banned
fuel pump noisy with low fuel. Added Lucas fuel treatment to lube it. Dramatic drop in noise. Driver mirror not folding. Front bearings went out. Not hard to replace. Other than that, solid vehicle. 2003 H2.
Old Apr 21, 2011 | 09:49 AM
  #40
GMCustomerService's Avatar
Originally Posted by parabat
Hello.
I would be happy to look into this further for you. In order to do so, I will need the VIN for the vehicle. You can either contact me here on the thread or via private message. I look forward to hearing from you.
Tricia, GM Customer Service.
