Most common problems with H2's
I do not recall the fuel pump being a common problem. And what is #6? Can't find the wiper motor?
I would also add that the air bag suspension seems to come up on this forum with some regularity.
yeah thats my foul i posted all the problems i heard of some recalls but never got anything fixed at the dealer since my vin number was never on the list
but i google the factory alarm issue and some h2 2005 have that problem
Here's another: People automatically assume I'm a Republican. (I'm not.)
2004
1) Oil pump supposedly went out (no pressure) $1500 (have to drop front axle).
2) Won't shift out of park (fixed myself) - you have to remove shifter handle and lift center plastic console up to view detached wire (usually black). Then resolder. If it happens at a bad time (no time is good), you can lift the center console and feel for the "button" and push that in and shift into drive. That will get you home.
3) Back utility plug does not work (not a fuse either).
4) Speedo and tach have gone out (wacky-never can tell speed).
5) Alarm failed and locked us out. (fixed under warranty).
6) Drivers side fluds when it rains and Hummer is left outside.
