Misfire P0300 won’t go away
I bought my H2 2005 SUT about 6 weeks ago. CEL came on at the end of the test drive. It was a vacuum leak. Seller fixed it. Anyhow my diagnostic scanner showed the same code with extremely minor misfire on cyclinder 6. Basically I have fixed everything on this Hummer starting with the simplest solution first: oil change and Techron in the gas tank. The P0300 and other codes indicating a lean fuel mix faded away immediately. Mine was well taken care of for most of its life but the last owner is a dealer with a lot of cars and barely used it, so it sat. So most of my issues are from sitting I think. I have yet to add in Seafoam because I won't be able to tell what is working. Just keeping it simple and not pumping money at it and throwing guesses. Right after the oil change I watched the diagnostics in real time and the misfire became intermittent. Engine is practically purring. Anyhow, has your situation improved?
I own an 03 H2 with a dreaded misfire that doesn’t seem to want to leave. The misfire is on cylinders 1, 5, 6, 8.
i have just replaced the coils , all plugs, all wires, yet the misfire is still present. The engine has 320km or 80k miles on it. It starts up good, great throttle response of the rpm’s. with one another.
not resolved yet, casual driving is fine, under any sort of load is horrible
I might just send it into a shop for one and done . I lead a busy schedule and have exhausted my comfortably and diagnostics.
My fuel gauge works, then reads empty for couple mins then works again, and the evap issue I could probably fix myself too, at the least it will fix that issue. With any luck it may correct the misfire but I have my doubts at this point.
without your comment I wouldn’t have even thought those two codes together could have been because of the other.
thank you
I hope it does help someone, to often I see people turn to the forums for help, then never update the outcome.
for the few mins it took me to update, hopefully save someone else some time!
