This looks Like This Guy Dropped Some Money Into This 2008 H2
Old May 22, 2026 | 08:06 PM
Mark R's Avatar
Default This looks Like This Guy Dropped Some Money Into This 2008 H2
Nice:
https://bringatrailer.com/listing/20...gn=Make_Update
Old May 25, 2026 | 12:04 PM
Gavin Costigan's Avatar
looks nicely done. same color as mine.
Old May 25, 2026 | 10:12 PM
Brunob00's Avatar
It will be interesting to see what this goes for - bidding is at $20k now. Typically if it wasn't done by Predator or Mash Motors, they don't get as much. This conversion appears to be a one-off by a custom shop called Just Driven. Interesting notes on this conversion:
  • Only appears to have one battery in the engine bay... the Predator and Mash conversions have two
  • There is no additional radiator support across the front... so interesting that they did not require the additional supports... the Predator and Mash conversions have a big piece of powder coated steel up there, probably because this has the OG GM radiator, while they install much larger radiators
  • Where the second battery would typically be placed, there is some piece of the diesel exhaust I have not seen before... typically there is a battery and filter there. Maybe that is part of the DEF system that the other teams avoid
  • HP is rated at 365hp which means that this engine was not tuned for the conversion, but just swapped. Predator upgrades it to 465hp by default and they just introduced a new option for 1000hp, and Mash starts at 400hp with options up to 800hp.
You know what we rarely see is an LS swapped H2...
Mark R
Mar 24, 2026 04:47 AM
Tran2tran
May 17, 2019 07:29 PM
Tran2tran
May 17, 2019 07:21 PM
Railroaded
Jun 25, 2016 07:58 AM
BlownChevy
Jan 8, 2008 12:32 PM
