Locked roof rack-no keys!
Old Jan 22, 2011 | 01:00 AM
Hitmannactual's Avatar
Default Locked roof rack-no keys!
Bought the 06 used and seller couldn't find keys.
Hasn't been an issue but I'm looking to add a light bar with a cross beam that resembles the stock crossbars.
A. Will it be an issues installing the new bar if I don't have keys to the old one?
B. How can I get the crossbars re-keyed?
C. Any other know issues im not seeing??
Old Jan 22, 2011 | 01:49 AM
parabat's Avatar
Default Lost keys
Hello.
I had the same problem. But if you look at the end caps there should be a serial number on them. If you take that number to a lock smith they will be able to cut you a new set for your roof rack. Mine cost me $5.00 CDN.
Hope this helps.
Cheers Malcolm
Old Jan 22, 2011 | 08:26 AM
calif phil's Avatar
Post the code and if my key is the same number I can mail you a copy of mine. I think they only use a couple of different keys.
Old Jan 22, 2011 | 07:27 PM
bosch's Avatar
Default same here
post the key number one of us will have the same key ...mike
Old May 15, 2011 | 04:02 AM
Justin D's Avatar
Default No Keys.. hello!
Hi, I also have no keys to my h2 roof racks. the serials are E003. any takers? thankyou!
Old Jul 17, 2011 | 10:20 PM
rakib1981's Avatar
Default Looking for roof rack oem key E001
Any idea where i can get one? Thanks.
Old Jul 17, 2011 | 10:26 PM
Muddydawg75's Avatar
you have to give us your lock number... they only made 5-6 keys....
Old Jul 18, 2011 | 09:22 PM
rakib1981's Avatar
Cool My key number is E001
Need key # E001. If anyone has that please let me know.. Thank you all.
Old Jul 26, 2011 | 11:13 AM
the9thone's Avatar
Default Needs SP5 key
Just got an 06 H3 with Roof Racks(no keys!).
Can anyone cut and send me one. I would greatly appreciate it.
I need an SP5 (GM Part# 88963247). Thanks!
Old Aug 1, 2011 | 08:40 AM
Sound pro's Avatar
You want need a key to install the light bar. The hardest part is fishing the wire through the rubber grommet below the front left ( driver side ) roof corner light. The keys are also very similar E001- E006, I have E-003 on factory X-bars and E005 on factory light bar and I can use either key on both, but it is alittle tricky, you have to rack it in and out as u turn it and they will work. Good luck.
