Liftgate fuse?
Not sure eather, and GM in their infinite wisdom don't have all the things listened for what they are for, some fuses do more that one thing. For example, I blew the fuse for the floor courtesy lights and I'll tell you they are not listed nor are they hooked with the dome lights.
I hand to sit down and systematicly pull and check each one till I found it.
Actually it's not as bad as it seems. Get yourself a good set of small needle nose pliers and you can pull and check them pretty quick. When you do find it make a note on the inside of the fuse panel for future reference ( & it wouldn't hurt to post it here)
Whats the fuse youre referring to labeled as in the manual?
oohank
09-25-2016 10:43 PM
JTummer
09-01-2009 10:56 PM
