Led lights adjustments h2 any one know how to don’t reach very far on high beams
Have you tried a screwdriver in that little hole in the front of the light. Also usually these lights require some kind of material to be removed at the mounting basket so they sit even. Hope this helps. I had to adjust mine down when i installed
If those are just some random cheapo Chinese ones, they are almost certainly total garbage with a crappy beam pattern that likely is blinding everyone else on the road.
I assume you already cut the back of the plastic buckets so that they can sit correctly in the bucket and mount properly. There is an adjuster for up/down that you can turn but make sure where the cutoff is so that you are not blinding other drivers on the road. There are some excellent 7 inch LED headlights but the good ones are not cheap. Any of the ones you can get from reputable dealers like The Retrofit Source, Lightwerkz, (brands like Morimoto, JW Speaker, KC, will be excellent but again, not very cheap. The higher end ones will generally have an excellent beam pattern like high end HID headlights.
LoJac963
Dec 20, 2013 02:12 PM
jpower9
Sep 13, 2010 08:26 PM
