Key Won’t Turn After fixing shift interlock harness 2003 Hummer H2
Old Jun 16, 2023 | 05:08 PM
Jumpman971's Avatar
Default Key Won’t Turn After fixing shift interlock harness 2003 Hummer H2
Hey everyone, I know everyone will start with the obvious but I couldn’t repair the shift interlock harness so I decided to replace the entire pigtail and connector matching the cable how they came out crimped the connectors, re-did the old ones that came out after a tug.
The key came out, but my issue is the key now will not turn or move to even turn the key in the cylinder. It was working before the harness change but I checked everything over and over….
is there anything else that should be looked at!?
Old Jun 16, 2023 | 07:27 PM
make sure the cluster shows the same gear you selected. there is also another solenoid in the steering column that locks the ket in the cylinder
H2Donkeykong
Feb 7, 2021 08:03 PM
Joyce04
Dec 21, 2020 11:32 AM
stoneman
May 7, 2018 01:41 PM
djslickrick
Nov 10, 2011 09:21 AM
dmachine007
Sep 15, 2011 08:50 PM
