Key stuck in ignition will not start but has power
Old Feb 14, 2023 | 01:35 AM
trm67's Avatar
Default Key stuck in ignition will not start but has power
I Drove my hummer H2. Got home put car in park. Key will not come out of ignition nor will it start the vehicle again I have a new battery, lights come, but radio does not. I removed shifter cover and checked wires no problem there. Car shifts into neutral and rolls but steering wheel and tires will not turn. I Wiggled key, shifter, steering wheel no luck. What can I try next. Can it be a fuse or bad ignition switch? Please help. Thank you
Old Feb 14, 2023 | 10:37 AM
look at your cluster and make sure it actually says you are in the gear you have selected as in park actually being park in relation to the shifter...
if not your shift cable bushing at the transmission range selector lever has probably disintegrated on you.
Old Feb 14, 2023 | 11:29 PM
finall's Avatar
Exactly. I bought a spare bushing on ebay, and now carry it in the vehicle. Sooner or later….
Likely never now that I am prepared. Bailing wire will get you home also, and great for broken dangling exhaust systems.
Pirate Maden
Feb 19, 2019 09:33 AM
DanH3
Apr 25, 2017 11:39 AM
hummerhonduras
42
Sep 19, 2012 11:49 AM
taz7593
Nov 18, 2008 02:01 PM
kevinj
Jul 25, 2007 02:34 PM
