| MixManSC |
Aug 21, 2020 07:55 AM |
Yes, it will work fine BUT you will need to use your original Hummer lens with it as the trucks and SUV's use a different front lens section. The lens part is easy to remove and reattach - just some plastic clips around the perimeter. Of course as I mentioned before, your mileage is stored in the cluster so your mileage is going to change unless you have the replacement reprogrammed with your mileage. You also must get one from a donor vehicle that has a gas engine - one from a diesel truck will not work.
