INJ 1 Fuse blows randomly
Old Aug 23, 2024 | 01:46 PM
Tank4354's Avatar
Default INJ 1 Fuse blows randomly
My fuse keeps blowing randomly. I've been dealing with p0300 codes for a little over a year now and then this started happening. It doesn't happen consistently but the fuse will blow during the start up and kill half the engine. I think it's a short somewhere but was wondering if anyone has dealt with this before or have any ideas where I could start looking to hopefully not spend 1000 dollars on repairs. It's a 2003 H2 at 188960 miles.
Old Aug 23, 2024 | 02:28 PM
zenith's Avatar
Doing a google search it shows you may have a bad ignition coil pack. Which will blow the fuse on that bank 1, could also explain the P0300 code, which is a random engine misfire.
My starting point would be to swap the ignition coils from one side to the other, and see if it blows the INJ 2 fuse. If so, most likely a bad coil pack.
Old Aug 24, 2024 | 10:37 PM
you cam also check the coil harness on both sides for rub throughs. not too expensive to replace or repair.
Old Aug 26, 2024 | 07:16 AM
Tank4354's Avatar
Thank you for the tip , I did that and it blew the inj 2 fuse. I then swapped two of the coils from that side back to the original to see if I could narrow down which coil pack it is exactly since I don't know how to test these coils with a multi meter. If you know how to test them I'd appreciate instructions as it would make it faster to diagnose which one is the cause.
Alex DjFlaco
Oct 9, 2020 09:48 PM
Tab Tucker
Sep 9, 2020 03:57 AM
chevin
Sep 6, 2018 01:56 AM
JerseyJoe
Nov 8, 2015 05:39 PM
MPWR99
May 3, 2009 09:42 AM
