Hummer U-Step Removal advice
Old Aug 29, 2019 | 01:51 PM
Harleydeal's Avatar
Default Hummer U-Step Removal advice
First post and seeking some advice! I am the original owner of a 2003 Hummer H2 with 68K miles. The rock rails have rotted away at the ends. I understand there is value in the U-steps that I am removing. My question...how does one remove them? I know the **** has to be unscrewed (not easy) but not sure how those other pins come out? I have never had the steps off. Any help appreciated!!!
Old Aug 29, 2019 | 05:23 PM
Post some pics..
Old Sep 1, 2019 | 10:40 AM
LoJac963's Avatar
The other pins do not come out, they are fixed in the U-step. Once the **** comes out the steps can then be removed. They were designed for quick on and off if one was offroading for greater clearance.
Old Sep 1, 2019 | 10:48 AM
Harleydeal's Avatar
Thanks, I see that now. Simple. IF the darn ***** would unscrew. But, no luck in getting that to happen. I’m sure it is galvanic corrosion so not sure how I am gonna proceed. Too bad because the steps are in perfect shape. Just need powder coating.
Old Sep 1, 2019 | 12:28 PM
LoJac963's Avatar
Usually the ***** won't come off if they are corroded. I've seen many steps for sale over the years where the plastic **** is cut off so the steps can be removed leaving the threaded portion stuck in the step. Still would be easier to work on off the rig than installed. I wonder if a little MAP gas would help loosen things up, probably melt the **** though.
Old Sep 1, 2019 | 12:39 PM
Harleydeal's Avatar
Right. I have them off the rig. The rock rails were rotted and crazy expensive to buy new now so I just threw some Nerf bars on as I only use the Hummer to tow behind my motorhome. I figure I will find a metal shop to try to get them off or drill them out. Thanks again!
Old Sep 12, 2019 | 12:35 PM
KTM640Dakar's Avatar
Yes every set of U-Steps eventually has the steel **** and aluminum step galvanically corrode together. All four of mind did it. If you cant get the **** to spin off then cut it right under the **** as to save the threaded steel shaft. Then take a nut and use the seized shaft as a threaded bolt. This way you can keep using the steps and just have to use a wrench to remove the nuts instead of the handy handle.
Old Sep 13, 2019 | 08:56 AM
Harleydeal's Avatar
Hey thanks for that. Trying to understand what you mean about where to cut them off? Do you mean to cut the **** off up to the shaft and leave the shaft on somehow? Not quite sure what it looks like under the ****. Thanks!
Old Sep 15, 2019 | 02:38 PM
Yes. If you can’t twist the **** because it is corroded then get a pair of channel locks. Spray with penetrating oil and try to unscew the **** with the channel lock pliers. Most likely you will ruin the **** or break it off the steel shaft. At that point cut it off leaving the steel threaded shaft stuck in the aluminum step. Use that threaded shaft as your new permanent bolt and find a similarly threaded nut as its future mate.
Old Sep 15, 2019 | 05:24 PM
2005H2
Feb 13, 2019 12:14 AM
therealdougkelly
Apr 9, 2017 05:32 PM
H3DONIST
Dec 31, 2010 02:28 PM
Norco1
Jan 24, 2010 10:45 AM
Norco1
Jan 12, 2010 07:54 PM
