Hummer h2 P0300 engine misfire
Old Jun 10, 2020 | 09:48 PM
Tran's Avatar
Default Hummer h2 P0300 engine misfire
What is my car
Old Jun 11, 2020 | 12:17 AM
according to your scanner it is a truck not a car and the manufacturer is HUMMER
Old Jun 11, 2020 | 04:48 PM
Originally Posted by Tran
What is my car
Does it look like this?
Old Jun 11, 2020 | 09:55 PM
Tran's Avatar
My car’s check engine light illuminates my dashboard.. It’s Hummer H2 2005.. I dont know what part in my car has something wrong?
Old Jun 11, 2020 | 11:22 PM
Dum Gai, Sum Ting Wong.
Old Jun 11, 2020 | 11:31 PM
Tran's Avatar
What does that mean?
Old Jun 12, 2020 | 08:04 AM
Mule's Avatar
The ECM computer is telling you the engine is misfiring. You can hunt it down yourself or take to a mechanic. Typical issues are spark plug issue, coil pack issue, vacuum issue, fuel psi, crank or cam sensor issue, head gasket leak...
good luck
Old Jun 12, 2020 | 06:41 PM
GM P0300 Causes
  • Faulty or worn spark plugs
  • Faulty spark plug wires or coils
  • Faulty fuel injector
  • Vacuum leak
  • Low fuel pressure
  • Camshaft sensor defective
  • Crankshaft sensor defective
  • Engine timing off
  • Leaking head gasket
  • Low engine compression
  • Poor quality fuel
Old Jun 12, 2020 | 07:19 PM
Tran's Avatar
good luck
thank you!
Old Jun 12, 2020 | 07:20 PM
Tran's Avatar
GM P0300 Causes
  • Vacuum leak
  • Low fuel pressure
  • Engine timing off
  • Poor quality fuel
thank you!
