Hummer H2 Manual Transmission Swap
Old Jul 26, 2007 | 02:05 PM
rao's Avatar
rao
Default Hummer H2 Manual Transmission Swap
I am pretty sure this is the first one anywhere
Supercharged Hummer H2 with every conceivable suspension and other upgrade now has a NV4500 manual transmission and a manual transfer case, all from a 3/4 ton Silverado.
Now it is no longer full time AWD, but can be switched into rear wheel drive for very impressive smoky burnouts (which it does quite well) and almost 50% better gas mileage than the race-built 4L65E auto transmission. It was done because the truck had gone through three 4L65E's and kept breaking tail shafts and the owner wanted a real transmission
Note smoke from the back tires only and how the truck is starts to rotate and then straightens out
and yes that is how clean the truck was after we worked on it.
Clutch Pedal and Manual Transmission Brake Pedal
Shifter - a short shifter was made using part of the stock manual transmission shifter and a tie rod end to provide the correct geometry to shorten up the shifts. He hasn't finished up the custom console yet, but the cupholders willsitill fit and it will look stock when it is all done
Transfer case shifter. The handle needs to be modified so that it comes out on the outside of the center stack, but that is a no-brainer
The NV4500
Old Jul 26, 2007 | 05:43 PM
Muddydawg75's Avatar
Default RE: Hummer H2 Manual Transmission Swap
That's cool....
Old Jul 26, 2007 | 06:44 PM
ttkresurfacing's Avatar
Are you the one who did the work? Where are you located? You do specialty tranny conversions?
Thanks,
Tim
Old Jul 26, 2007 | 06:59 PM
rao's Avatar
rao
ORIGINAL: ttkresurfacing
Thanks,
Tim
I did most of the reasearch into the swap and did the actual swap with the owner of the truck. Just outside of Chicago - Naperville, IL I have done several engine swaps, my most current is a BMW M3 with a LS2/T-56 drivetrain
Old Jul 26, 2007 | 07:34 PM
pmalla5's Avatar
thats so nice how fast is it?
Old Jul 26, 2007 | 08:41 PM
blackstangs281's Avatar
Cool
Old Jul 26, 2007 | 09:45 PM
Think you can make the new 6 speed Allison tranny work in a 2003 H2? Would want itselectable 4x4. If you think it's possible please message me.
Thanks,
Tim
Old Jul 30, 2007 | 08:14 PM
djguy988's Avatar
Is this something the shop offers or just a one time swap. I would be interested in a conversion in my '03.
Old Jul 30, 2007 | 08:44 PM
rao's Avatar
rao
I suppose we could do another one, but it is not an inexpensive proposition. If you are interested PM or e-mail me.
Old Jul 30, 2007 | 08:50 PM
littlehummerboy's Avatar
Definatley neat. I wish we had ordered a manual for the H3. Automatic is nice, but I find myself reaching for the gearshift like I want to shift.
