Hummer H2 anyone know how to replace the fuel filter
All other years has to drop fuel tank
Cheapest way is have someone to help!
Drop Gas tank cover and then drop almost empty tank. The quick connect fitting are some what aggravating but the filter is actually on the pump so replace entire fuel pump and don't skimp on buying the cheapest buy 1 that has multi year warranty
Also never run your tank on empty! If the fuel that's being pumped has a little trash it will eventually destroy the new pump if repeatedly ran on empty I myself try to never let it get below a quarter tank. It will take about 3 hours to drop tank and clean inside of fuel tank and replace pump or you can pay someone about $1200 Todo it for you
It's not Hard if you have a little bit of knowledge it will install easily it's just a little time consuming so take your time
HuMmErDXB
Jan 21, 2008 02:21 PM
