-   Hummer H2 (https://www.hummerforums.com/forum/hummer-h2-8/)
-   -   Hummer H2 anyone know how to replace the fuel filter (https://www.hummerforums.com/forum/hummer-h2-8/hummer-h2-anyone-know-how-replace-fuel-filter-34347/)
Lms Scratch Dec 5, 2014 02:08 PM
Any help would be appreciated.
H2Miami Dec 5, 2014 02:19 PM
Not typical easy job. .. don't take my word but I read somewhere it is inside the fuel tank .
Thanks to Gm for making the fuel filter replacement so fun
madmayo Dec 5, 2014 02:58 PM
x2 when I had my truck in for maint. I asked my mechanic to change the fuel filter. He told me that it is in the tank and will last the life of the truck. He also said that it would really take a lot too clog it.
Are you just trying to be proactive as I was? Or is there a reason you want to change it?
EDIT: this false. 03 has a filter mid point by crossmember in front of tank
woodwardsh3 Dec 5, 2014 04:25 PM
no filter on the h3 ether
elkgrunt Dec 6, 2014 07:55 AM
I don't know what year you have but 2003 is the only year that has the filter on the outside of the tank.
madmayo Dec 6, 2014 08:08 AM
Really? I've got an 03 my mechanic said it's in the tank. I never verified it. Just took his word . Will have to get under there and look.
yoymon Dec 6, 2014 08:53 AM
2003 has external fuel filter about middle of truck, google the location youll see it
yoymon Dec 6, 2014 08:59 AM
http://www.justanswer.com/gm/46sf8-h...03-hummer.html
LoJac963 Dec 6, 2014 05:30 PM
In tank fuel filters are usually strainers not an actual filter. Not sure about the 2's but the strainers just prevent large debris from entering the fuel system.
ukdave Dec 7, 2014 02:02 PM
This is a fairly easy job if a bit fiddly the filter is tucked above the cross member in the middle of the truck. once you locate the filter you need to squeeze the tab together and the pipe should pull out. be prepared for fuel to leek out as you pull the pipe so try and be quick i held the new filter nex to the old one while i swoped them over then tye rap the new one back in place mine is a 03 h2
