Hummer h2 2007
Old Feb 16, 2025 | 01:20 PM
CHiNOLA's Avatar
Default Hummer h2 2007
So I just bought myself a hummer for my birthday! One thing I noticed was the heated seats were not working. Would that be a quick fix?
Old Feb 16, 2025 | 07:25 PM
probably not unless some disconnected a seat heater.
usually the seat warming pads go bad and cause the fault. they are stitched into the leather seats and GM does not sell the leather any longer.
Old Feb 20, 2025 | 01:26 PM
Chrmer3's Avatar
You can find new leather seatcovers on ebay from a place in TX they are outstanding and take a couple hours to remove/ replace seat heaters/ new leather covers & reinstall. Its an easy job (the original were stitched into the leather cover- these will lay down on the seat foam pad & then you cover. Works the same & looks the same after leather installed. The seat heaters I used are were Dorman 641-105 but I bet these would be the same and are inexpensive. If you are on a budget - buy these on ebay & you can simply unplug the harness under the seat & plug in the new replacement to see if functioning before spending money on the leather seat covers &your 2 hours to install (seat is literally 4 bolts & a couple connectors & lifts right out of truck- they use a female torx but i think a certain socket also may work on those torx heads)...- https://www.ebay.com/itm/30582945772...QaAq-dEALw_wcB
the leather seat covers you can get here (I am unsure of the quality on these but this gives you an idea) Mine came from an upholsterer in Houston and they were exact
:https://www.ebay.com/itm/26571976329...KW2GWHQPNJ8ZKH
mine came from this company- they were perfect and install is super easy (Richmond Auto Upholstery in Houston TX)-
https://www.ebay.com/itm/32256135069...Bk9SR8q9_8ykZQ
Old Feb 21, 2025 | 09:32 AM
HellHoof's Avatar
What everyone else said. Here's a great video of how to do the work.
HUMMERHATS
New Member Area
Dec 1, 2023 02:33 PM
PaulDengler
Private 'Wanted' Classifieds
Feb 11, 2020 12:33 PM
jefftaylor007
Aug 14, 2019 12:27 PM
hawknthasky
Oct 27, 2009 07:36 PM
