How to Clean Out Your Sunroof Drain All The Way Down
Found this on Flea Bay... I'll have to use it and check it out. Just got it a while back. Looks like it's do the job to clean any Gack out.. Plus does the doors and Gas Tank Vents and any where water should drain form your ride.
https://www.ebay.com/itm/386013923286 |
Got me curious.... I actually replaced the rear drain tubes on mine since one was pinched off. The link you gave shows that as 150cm long which is just over 59 inches. I just measured one of the old drain tubes I still have around and its right about 69 inches long....
Originally Posted by MixManSC
(Post 404771)
I'm confused?? Rear Drain Tubes?? I have 09 SUV H2.. Where would I find rear drain tubes....?? I was going to use mine on the sun roof drain and door drains it there their. Also On My 65 Vette Windshield cowl drains which come out under the frame. |
There are 4 sunroof drain tubes. The fronts gown down through the A pillars, the rear tubes gown down C pillars behind the rear doors and through the floor just in front of the rear tires.
(Post 404787)
The front drains that go down the "A" Pillars causes me a lot of head hurts...Wet the head liner above the "A" Pillar. The water actually runs down inside the front pillar inside plastic trim and passes the pinch welds where water backed up and leaked in. Turns out the pine tree next to my drive way sheds it's needles and they all packed up inside the "A" trim. When I removed the "A" trim it was like a flat layer of pine needles. The water would run down the roof drain with the needles floating along and clog up that area. |
Originally Posted by Mark R
(Post 404798)
https://cimg4.ibsrv.net/gimg/www.hum...fff274ab29.jpg |
Not the roof drains, the sunroof drains. The sunroof module has a small plastic gutter around it under the headliner with 4 drain tubes. It is designed to allow some water to drain around the sunroof, into the vehicle and then out the drain tubes. If they get clogged the little trough fills up and runs over.
(Post 404801)
(Post 404801)
(Post 404807)
On My 09 I have one big Drain tube at the driver side corner... Never noticed any more.. Are they in that trough? In the rear...Never looked back there...always kept the front drain clear.
https://cimg3.ibsrv.net/gimg/www.hum...a84dff0985.jpg |
