Horrible Idle
Old Mar 27, 2023 | 07:17 PM
Devildog71's Avatar
Default Horrible Idle
Brand new to forum but I’ve referenced posts here for quite some time. I finally joined. Ive got a 2003 H2 with 100k miles with a whipple supercharger. Truck is idling extremely rough and I’m at a complete loss. I have been working on my own vehicles for many years and consider myself very mechanically inclined but this is kicking my ***.
Here is info so far;
PO300 code
The below items all New ACDelco parts
-Spark plugs (gapped properly)
-Spark plug wires
-Coils
-Fuel injectors (all tested prior to install)
-MAF
-Fuel regulator
​​​​​​-Fuel filter
-O2 sensors with new exhaust from manifold back to include cats.
I’m thinking vacuum leak? I’ve sprayed carb cleaner around all areas I can think of but now I’m thinking smoke test.
Any thoughts out there before I drive this into the ocean?
Old Mar 27, 2023 | 07:35 PM
check your fuel trims to see if it is running rich or lean. might want to also check the purge valve.
Old Mar 27, 2023 | 08:20 PM
legerwn's Avatar
I'll second what bronxtech said, along with the idle timing, throttle position at idle and mass air flow in grams
Neal
Old Mar 27, 2023 | 08:24 PM
Devildog71's Avatar
Thank you. I will give it a shot.
Old Mar 27, 2023 | 08:56 PM
Devildog71's Avatar
Canister purge valve or purge selonoid on engine or just do both?
Old Mar 28, 2023 | 12:54 PM
maybe try disconnecting it at the engine port and capping it to see if it is the issue before throwing new parts at it. if the old one is stuck open then it could be the idle issue but if it is closed or capped off for testing and the idle is still bad then it is not your issue. and you need to look further. check the fuel trims to see if it is a fuel delivery issue. worn pump.
Old Mar 28, 2023 | 07:39 PM
Devildog71's Avatar
Default Solved
Purge valve selonoid! Running like a champ. Thanks for your help. I’m glad I finally joined this forum.
Old Mar 28, 2023 | 09:06 PM
glad it resolved your issue.
Daniel Z
Oct 31, 2021 01:02 PM
NMH3
Sep 6, 2021 06:35 PM
khanson.82
Sep 15, 2014 04:26 PM
marine6132
Feb 15, 2014 07:37 AM
jumperdp
Nov 19, 2008 06:16 PM
