HELP! Passenger side not working
Old Jan 25, 2021 | 09:48 PM
Ray03's Avatar
Default HELP! Passenger side not working
I have read all the other thread about this issue, but need some advise please!
Issue = Passenger side seat doesn't move at all in any direction (ex, up/down back/forward), but lumbar button functions just fine and the heated seats work.
I read an old thread that recommended to replace the 25 amp and 30 amp under the driver seat fuse box (by left leg of driver)... the aluminum ones
I did pulled both fuses (breaker) out, but no luck!
Do you guys recommend I replace them? not sure if thats the issue since the heater and lambar works.
Any input will be greatly appreciated!!!!!!
Thank you!
Old Jan 26, 2021 | 11:23 AM
Ray.... you posted this in the WRONG section.
Whenever you post a question, Year, Model, Miles. We need to know what you are talking about, H2, H3 etc...............
I can move this to the vehicle section once you provide what your vehicle is. Works like this, all H2 questions go in the H2 section, H3 questions, H3 section.
Old Feb 1, 2021 | 06:40 PM
Ray03's Avatar
Hi Doc, sorry for the late response,,,,
Its a 2003 hummer H2 with 110k miles.
My apology for posting in the wrong section.
Thank you!
Old Feb 3, 2021 | 12:09 PM
No worries, just trying to get you some help.
Given the age of these vehicles, I would try easy stuff first, like cleaning the seat electrical connections with electrical contact cleaner by CRC.
Old Mar 10, 2021 | 10:34 PM
Pulse_GTO's Avatar
Did you ever figure out what the issue was? I have the exact same problem with my 03. Passenger side seat is stuck all the way back and won't move in any direction but lumbar still works. My seat heaters do not work, but they were bad before this happened.
Old Mar 11, 2021 | 05:39 PM
first check your fuses then check your seat switches and the harness under the drivers seat as thats where the seat module resides.
sellingsam1
Oct 19, 2018 08:10 PM
dunringil
21
Jul 16, 2013 11:00 AM
vipermuscle83
Oct 21, 2012 02:03 AM
Snowaterdude
Oct 30, 2011 09:04 PM
saywhat
Oct 6, 2007 06:13 PM
