Help needed with H2 front driveline/transfer case vibration
Old Jul 4, 2018 | 08:00 PM
Justin Gustman's Avatar
Default Help needed with H2 front driveline/transfer case vibration
First post, fighting a huge issue with harmonic vibration and wrecking transfer case bearings. I've replaced u-joints, balanced shafts, on my third rebuilt t-case from Transfer case Express, and now this one looks like it may now be junk at about 400 miles. The vibration come on at around 63 and worsen slightly with increasing speeds, increased vibes when acceleration under loads or going up hills. We just arrived for the 4th after driving 190 miles and I noticed it the driveline started howling at around 65-70 like a pinion bearing or something. Upon arrival the transfer case was so hot you could not touch it more that 1/2 a second and seeping oil from the front and rear shaft seals...Also tried 4 hi lock briefly and it made some groaning scraping noises when turning and it was binding up. Didn't want to move without hitting the gas. I have gone through everything, driveshafts are checked for runout and indexed for the smoothest operation. I have put new solid bushings in the front differential just before the trip. Made no difference in vibration. If you pull the front shaft and run it in 4 hi lock, vibes are completely gone. I have checked the front driveshaft angles and see a big problem that can't be fixed so chime in if your trucks are the same. The front driveshaft u-joints are in the wrong plane, opposing each other. The front transfer case angles upward, the front diff angles upward also. The front diff should parallel the transfer case pointing down correct??? This looks like the cause of constant vibes.
Old Jul 4, 2018 | 08:06 PM
Driveshaft angle at t-case is approx 3.9 deg up, front diff driveshaft angle is 3.6 upward opposite of what conventional wisdom dictates.
Old Jul 10, 2018 | 12:36 PM
Year and miles would be helpful.
Posting some pics would be too.
Upon casual observation, perhaps Transfer Case Express is less than stellar at what they are offering you??
Old Jul 10, 2018 | 02:37 PM
It’s a 2006 with 127,000 on it now. All stock. Tires are within 2/10” diameter, center tread is very close to even on all 4, outer edges of fronts are slightly smaller. That was a question from others with awd tranfer case issues. Don’t know what other pics you want.
charlie6017
Jun 11, 2019 12:22 PM
HUMVEE_H3
Aug 6, 2018 12:49 PM
Justin Gustman
Hummer H2 SUT
Jul 8, 2018 10:07 PM
thorg113
Mar 27, 2018 08:54 PM
vanderbeek
Mar 24, 2017 06:22 PM
