Help needed
Old Jul 29, 2013 | 01:24 PM
burnt orange hummer's Avatar
Default Help needed
Hello everyone! nice to meet everyone. I have a 2003 hummer h2 and recently installed a spare tire carrier and license plate holder everything wen great!! except wiring up the license plate light where do I wire it up to??? thanks for the help in advance!!!
burnt orange
Old Jul 29, 2013 | 01:36 PM
Caraddict's Avatar
I think there is a wiring harness for it...
Old Jul 29, 2013 | 01:43 PM
I have looking all over for about 2 weeks and nothing...
Old Jul 29, 2013 | 08:52 PM
calif phil's Avatar
You can tap into a tail light wire if you cant find any harness.
Old Jul 30, 2013 | 08:05 PM
Circuitguy's Avatar
Take the time to call us when you can, we can have one of our techs tell you where to attach that wire. 1-916-714-9988
Old Aug 2, 2013 | 12:30 PM
H2CANEPADESIGN's Avatar
There is a junction box behind your rear bumper if you crawl underneath the car and look up..its a little to the drivers side about a foot and a half behind the bumper. there should be a plug that doesn't have any wires connected to It. It is wired for you rear lights. You have to take a test light to the pins individually to determine which is ground and which is power as I don't remember when I wired mine. You can buy the metal crimp connectors from the dealer that will work in that plug to make a harness. I ended up drilling a very small hole in plastic bumper to connect to lic. plate lamps.
there is a very detailed post on all of this on the forums .. you may have to search for a while but its there as I went through all of this a couple years ago. I have since sold the carrier as I cannot tow my new trailer with it on.
Old Aug 3, 2013 | 08:01 PM
thanks for the help!!! that definitely helps out!! it puts me on the right track at least I have a place to start. I found that group of plugs under the back bumper. ill look for the thread on hummer forums.
Thanks for the help!!
Old Apr 4, 2016 | 12:16 AM
Brandon C's Avatar
Default Junction box
I took photos while wiring up my spare tire license plate light. Use an ohm meter, but I think white was ground for me.
Alex2012
18
Mar 6, 2014 06:51 AM
Caraddict
Aug 19, 2011 06:29 AM
hummerman62040
Nov 11, 2006 09:26 PM
davyo
Aug 2, 2006 07:04 AM
importkiller
Jul 21, 2006 01:59 PM
