Heated seats turning on/off (which fuse to pull?)
Old Jun 7, 2023 | 09:52 PM
Dark Abyss's Avatar
Default Heated seats turning on/off (which fuse to pull?)
Newbie here...My heated seats on the drivers side has been randomly flipping on. As I never use the heated seats, I thought I'd pull the fuse.
However the fuses I pulled didn't stop it from going on.
SEO B1 (15 Amp)
IGN 3 (10 Amp)
What's the right fuse to pull to disable the heated seats on a 2006 H2? (this is really burning my rear!)
Old Jun 8, 2023 | 07:05 PM
oceanbrave's Avatar
For reference SEO B1 and IGN 3 are for the Left & Right Rear Heated Seat Modules which operate independently from the front.
Honestly, isolating the heaters may not be possible, there is a 30A Circuit Breaker on the I/P Relay Block inside near the LH Kick panel,
but beware, removing this will completely power-off the Memory Seat Module which may generate a DTC and affect driver and passenger seat controls. Also it may not be wise to unplug any module connectors as disturbing them could cause some of the "over-heated and burnt-out" connector issues mentioned elsewhere in the forum
The DDM is most likely the root cause, followed next by the heated seat switch assembly. The DDM can easily be removed using plastic panel levers (no need to dismantle the door) if you unplug the 12-Way Green Plug (connector C5) and the problem still exists then it's the DDM otherwise its the switch assembly and vice versa.
If the DDM the mostly likely cause is corrosion on the main PCB, if you're lucky it might clean-off with a small brush and IPA, the pic below shows the PCB area most likely concerned:-
It you look closely you can see some track repairs made to fix a similar problem, the IC HC589A handles the heated switch inputs specifically pins 2 and 4.
Repairing a DDM may be a "long-shot" but worth a try before buying a replacement /new one
If replacing, check the model year, especially if a used one, the seller may quote 2003-2007 but there are differences (express windows Up/Down was not a feature pre 2005) the seller may not be aware of this.
Old Jun 9, 2023 | 12:45 AM
finall's Avatar
Ghetto repair: Just disconnect the seat heater pigtail under the affected seat. I forget which one it is, maybe blue or green. Check service manual. Simple.
Old Jun 9, 2023 | 04:14 PM
Dark Abyss's Avatar
I took the DDM off (had to remove door...old plastic was stubborn) and clean it with contact cleaner. Looks like I've got part # 15251167 on my 2006 Hummer H2. I didn't encounter any water, but it was dusty! I cleaned the contacts on the other side and also on the module with the heater controls. Since it happens randomly, I'll let you know if it continues to happen.
This was a big help on info. Thanks!
Old Jun 9, 2023 | 04:15 PM
Dark Abyss's Avatar
"Simple with a service manual". Where can I get one online?....free?
Old Jun 9, 2023 | 09:07 PM
Old Feb 23, 2025 | 04:36 AM
C216had's Avatar
Did your clean fix the issue?
ski.dive
Oct 5, 2022 08:53 AM
Jeje Ali
Oct 26, 2019 07:30 AM
ultraclassic01
Nov 26, 2018 09:24 AM
Titus
Mar 28, 2010 11:15 AM
