heated seats question
i wanted to know if anyone else could lend some advice on what is happening to my driver side heated seats, i checked the plugs and the fuse in the driver side but i cant the root of the problem. the thing is, it does turn on for either function for maybe one second but then turns off immediately after.. also the other features on that panel does work such as the memory seat controls.. :confused:
One of your seats heating pads has a short in the pad.Sometimes you can mash around on the seat and figure out wich one it is.On the other you can take it in an have the dealer ship reprogram the module,(door buttons)but you probally will have to replace it, and then have the new one reprogramed.
Short in heated seat?
Why would an open circuit in the seat heater cause the light to wink off after 2 seconds, but after you drive a mile or so it will stay on? This does not make sense. Are there any HUMMER MECHANICS out there that can respond to this?
Hello, i'be been a mechanic for 35years I'ved owned a dealer ship for 20yrs. I've had 12 h2s -5 blk-3 red-2wht- 1 yel-1 Orange-MY Dealership deals in performance cars.We are a procharger distibutor,and computor tunner. and we have a in ground dyno jet dyno.Last h2 we tuned made 40 more rwhp.Even install superchargers on h2s. We mainly work and install superchargers and custom tune corvettes.We also sale rims and tires and other perfomance accessories.We have a wrecker service and wrecking yard and window tint shop for 35 years.My point is I mainly sale and work on gm products.There's basically only 3 things that can go wrong ,short in door harness or heating pad or door module.Keep in mind its just a suggestion.Call a dealer and ask them,sometimes repetitious problems they can tell you what it is.
Originally Posted by mawinc
(Post 215791)
Heated seat driver side heat switch
My switch has a carbon fiber trim covering the lights that tell you what power you are on it works fine just would like to know when you first push the button what level is it on
