Heated seat keeps turning on.
My drivers side seat heater keeps coming on, I turn it off and it comes right back on. Cold out right now so I don't mind but anyone run into this. I figure I'll just pull the switch and clean the contacts and replace if that doesn't resolve it but curious if others have run into this.
You need to set the “memory” of the seat. I doubted this sage advice when I first heard it… basically just press and hold 1 on the seat memory. I would bet that resolves your issue :)
seems to happen sometimes if you disconnect the battery for any reason also…. (memory control on the drivers door) 3 seconds and you should hear a double chime. |
BOHICA
The heater switches, heater LEDS and seat heaters interact via software, so Chrmer3 may be correct, certainly worth a try first. If not, other possibilities are:-
Hopefully is will be just a memory seat issue. Good luck 👍 |
Thank you for the replies, sadly setting memory was not the easy fix I hoped for.
I'll move on to oceanbrave suggestion next, it sounds like it's my issue based on the existing threads I've read. At least it started happening in January instead of June. |
i had the same issue going on as well.....it took several resets but if finally worked on the 3rd try
