H2 wont start!!!!
Old Sep 3, 2013 | 02:37 AM
S Reynold Gudam's Avatar
Unhappy H2 wont start!!!!
Anybody....please help!!!
I notices a Blue LED Blinking at the most left edges of Dash driver side(near to windscreen). Its never blink before.
Can anybody explain what light is it? Is it OEM or Aftermarket?
I swap the starter relay and still no crank. But when i direct wire from battery + terminal to the starter relay,its start. What could be the problem?
Old Sep 3, 2013 | 06:36 AM
yoymon's Avatar
I have a small blue light (never been lit) left of the steering wheel on dash I assumed it was part of aftermarket alarm/remote start, I don't know because I bought it with fuse pulled for this because guy I got it from supposedly lost keyfob for it, does your have an aftermarket alarm/remote start?
Old Sep 3, 2013 | 08:08 AM
the day i bought the car before it its come with VIPER alarm remote but its doenst work anymore so i just use the key. I bought the car direct from used car importers so i got the car "as what it is basis". it doest give me a headache for the 1 year of ownership but after a year the problem comes...
This problem come after battery drained out.
Which fuse did the guy remove?
http://www.viper.com/ShopViperProduc...?ItemCode=479V
Old Sep 3, 2013 | 08:15 AM
yoymon's Avatar
mine is supposedly a viper as well, I bet that what blue light is for, im not sure which fuze he told me about it when I was buying it, have had it like 3 weeks, the fuze panel on drivers side, the one that has the cover that pops off on the side of dash board has a button and an on off toggle switch there, they are definitely part of aftermarket install, open that panel and see if the toggle was installed there for yours and trying turning it off
Old Sep 3, 2013 | 08:20 AM
yoymon's Avatar
the battery draining out might have set or reset something having to do with remote start/alarm, im taking mine to a pro to have my system looked at to see if it will work...im thinking you might want to call your local viper place or there help line and tell them the problem, I bet it has to do with that
Old Sep 4, 2013 | 04:05 AM
aHAh.....after several troubleshooting i manage to get the alarm off...
You need to find where is the location of VELET SWITCH.
Steps are:
Open the door(let it open)
Turn your key to on possition(dont crank),Within 5 seconds press, release, press and hold the velet switch for 5 seconds. The Blue LED will turn off... Turn off the key and thats it!!!!!!
Start your beast back and it should be crank and roar!!!!
Hope this help others later!!!!!!
Old Sep 4, 2013 | 08:43 PM
yoymon's Avatar
was the valet switch the toggle on off switch? I see that on mine in fuze panel, just curious since I haven't had it looked at yet, im going to get it working or just have new sremotestart/alarm installed all together
Old Sep 4, 2013 | 10:13 PM
yup it is... mine also located inside fuse compartment!!!!
many thanks!!!!!
H3ummer
Aug 21, 2023 09:51 AM
simota1
Nov 24, 2021 12:45 PM
Deracing07
28
Dec 1, 2012 06:47 AM
real7446
Jan 5, 2008 07:47 PM
Sugardaddy
18
Mar 17, 2007 05:47 PM
