H2 swinging like a boat 😅
Old Mar 4, 2020 | 12:03 PM
Nasser Aldrbass's Avatar
Default H2 swinging like a boat 😅
My hummer is swinging after 60 km/h , i tried many workshops each one aske me to change shocks , front arms and steering arm and still has same problem did that happen with any one?? Whats the solution?
Old Mar 4, 2020 | 12:22 PM
Booch's Avatar
Steering stabilizer?
Old Mar 4, 2020 | 12:34 PM
Changed already!!
Old Mar 4, 2020 | 12:37 PM
have they check your stabilizer links and bushes?
Old Mar 4, 2020 | 07:19 PM
Chrmer3's Avatar
Are your bump stops present?
https://www.1aauto.com/chevy-gmc-hum...SABEgI7f_D_BwE
also h2 is never going to handle like a slot car racer......
the bump stops tops are most likely missing on your front arms - they are integral to your front suspension diving and wobbling -
let us know -
Old Mar 4, 2020 | 07:22 PM
Chrmer3's Avatar
Also - if you have “steering drift” your steering gear box is also probably shot. Common on these.
Old Mar 5, 2020 | 02:48 AM
let us know -
thanks for responding, yes bump stop feont and rear is new as well
Old Mar 5, 2020 | 06:32 AM
tharber's Avatar
How about the front hubs?
Old Mar 5, 2020 | 07:24 AM
Hub is good , bearings are new 😕
Old Mar 5, 2020 | 07:49 AM
calif phil's Avatar
What air pressure are you running in the tires? Have you tried rotating your tires front to rear to see if that changes anything?
