H2- pulling front drive shaft out??
Old Dec 30, 2010 | 07:54 AM
Hummer007h2's Avatar
Default H2- pulling front drive shaft out??
Is there any way to make it 2 wheel drive without problems??? I have a H2 with 37" tires. MPG is crazy so I was thinking about pulling the front drive shaft out. Dont go off road much. If I did I could easy bolt the front shaft back in. Any info would be very helpful... thanks
Old Dec 30, 2010 | 09:13 AM
cdwaterman88's Avatar
when i dynoed mine i had to pull the front shaft out and the fuse to the traction control system. i figured this out on the second try. gauges lit up like a christmas tree when the rear started spinning and front wasn't moving!
Old Dec 30, 2010 | 12:41 PM
Thanks!! So it can happen and without any problems?? I have every power upgrade except a supercharger or turbo.
Old Dec 30, 2010 | 10:25 PM
i am not sure about problems down the road. the dyno only took about a couple of hours.
flyinghunter
16
Apr 30, 2014 11:55 AM
HoneyBee
Jan 8, 2014 04:58 PM
SSP Boss
Apr 29, 2011 10:04 PM
adonatz
Apr 25, 2011 04:51 AM
joenuzz
Aug 11, 2010 03:57 PM
