H2 Front axle destroyed
Old Mar 24, 2021 | 01:14 PM
ACCLR8N's Avatar
Default H2 Front axle destroyed
The ring and pinion shop said the whole thing is junk. Find them another one to rebuild. Don't drive your truck around with the transfer case in 4H Locked boys and girls. What is different about the 2008-2009 front axles from my 2005? Compatibility seems to be 2003-2007.
Old Mar 24, 2021 | 01:18 PM
i believe they have a different gear ration for the 6 speed
Old Mar 25, 2021 | 03:27 PM
ACCLR8N's Avatar
You are correct. I went ahead and picked up the 2009. It has 3.73 gear versus the 4.10 in my 2005. I can't see any external differences outside of the case is cast with a different part number.
Old Mar 25, 2021 | 05:02 PM
outside should be similar but the ring and pinion gears inside the differential would change
Old Mar 25, 2021 | 07:06 PM
Of course if you put 3.73 up front you will want to regear the rear to match.
Old Mar 25, 2021 | 07:56 PM
4wd axle ratios front and rear need to be within 2% (at the most) of each other!
Old Mar 26, 2021 | 08:06 PM
ACCLR8N's Avatar
No, I wasn't planning to run it without matching gears.
Old Apr 10, 2021 | 10:38 PM
ACCLR8N's Avatar
Just to close this out. The years are interchangeable if you match the gear ratio (replace ring and pinion). The innerds are different so you can't mix and match components like axles or carriers.
Gavin Costigan
Mar 14, 2021 11:07 PM
bflank
Oct 5, 2017 05:18 PM
hrcentury21
Dec 7, 2015 12:06 PM
kakash
Mar 25, 2013 05:22 PM
Jman1928
Jan 27, 2012 09:02 AM
