Fuel pump wiring
Old Jul 10, 2014 | 02:26 PM
ingydrummer's Avatar
Default Fuel pump wiring
I decided to let the pump drain my fuel tank since it still works but i'm not sure where to put the hot and ground. I don't want to fry the pump cause it's my last resort to drain the tank. I put a drain tube on the discharge end of the fuel filter, but when I turn the key on it only pumps for a second then stop's. Now I need to pull the plug from the pump and hot wire it to run constant till the tank is empty. The wires to the pump are:
Big Grey or white
Big Black
Small Purple
Small Black
Hoping there's a Tech out here that knows which terminal I need to jump. I'm getting desperate. Thanks for any suggestion's.
Old Jul 13, 2014 | 08:45 AM
Well, problem solved. Jumped the relay and let the pump run until tank was empty.
SuperH1
Jul 11, 2011 10:31 PM
gcompton
Jan 13, 2011 08:10 AM
*fill-up*
Sep 11, 2010 08:57 AM
edrust
Jul 30, 2010 12:45 AM
Kimberly
Jul 27, 2008 11:23 PM
