Fuel pump replacement H2
Old Jun 30, 2011 | 01:57 PM
blackdragon's Avatar
Default Fuel pump replacement H2
Do I need to remove / lower the gas tank to replace the fuel pump on a H2 ?
I cannot see any access panel from inside cabin floor. the please help..
Old Jul 6, 2011 | 02:38 PM
HumminNBoatin's Avatar
Yes you have to drop the tank. I paid to have mine done as it went out in Februray with a full tank. There was no way I was gonna do that job at home in the cold with a full tank. At a dealer expect to pay roughly $900 to have it all done.
Old Jul 6, 2011 | 03:08 PM
Muddydawg75's Avatar
You can do it yourself though.... the hardest part is dropping the Tank, like Eric stated. I piece of plywood, a ratchet strap, and a floorjack makes that MUCH easier.
The next hardest part is the retaining ring. I suggest a hammer and a brass drift to tap it into freedom.
The pump is around $400ish... and comes complete.
Just for the sake of curiousity, why are you replacing it? for performance or failure?
Old Jul 6, 2011 | 10:00 PM
parabat's Avatar
My fuel pump went on my 03 and it was $600.00 for the fuel pump and another $600.00 to have it installed and a new fuel filter put on the H-2. Total was just over $1200.00 after tax and all the other charges.
Old Jul 6, 2011 | 10:26 PM
That's a huge ripoff....
I was wrong... the pump is only a little over $300 now... for an OEM pump...
GM Parts | GM Accessories | GM Parts House Store H2&year=2003&graphicID=GP03560&callout=7&catalogid =2&displayCatalogid=0
Old Jul 11, 2011 | 12:05 PM
BIGT2148's Avatar
yea 1200 is a big rip off. If you can try to do it at home.
Old Jul 11, 2011 | 12:12 PM
Default Update
Thanks everyone for your advise,
My Mechanic got the engine started today by connecting 12volts directly to the original fuel pump from a separate battery.
The engine ran smoothly and check light went out.
Does anyone have some ideas what to do now ??
Im thinking a broken wire on the fuel electrical harness somewhere or a bad FPCM, but Im not sure the engine would run if the FPCM was stuffed, seems strange.
Old Jul 16, 2011 | 08:08 PM
AndyMac's Avatar
Just for future reference, my lines rotted off the top of the sending unit. I ordered a new complete unit from ebay for 150 bucks. Also got a new retaining ring from GM for 10 bucks or so. Took a couple hours, but it wasn't a huge job. Just made sure the tank was near empty when I dropped it, and then completely emptied it before putting it back up.
As for your problem, I would just grab some wiring diagrams and start tracing wires. Good luck!
Old Jul 18, 2011 | 07:26 AM
calif phil's Avatar
He needs to check and see if there is a power and ground to the fuel pump. I would suggest that the ground to the pump is bad, maybe a fuel pump relay. It could still just have a fuel pump that is worn out.
Old Apr 16, 2013 | 10:03 AM
James Settimio Biscardi's Avatar
Default fuel leak in 2005 H2
I have a fuel leak, dripping from the bottom of the tank. If this is a line or sensor, how many hours labor to drop the tank and repair a line, then finish?? Any feedback. I would assume this job should be no more then a couple hours
