Fuel pump kill switch
Old Sep 25, 2023 | 03:31 PM
zenith's Avatar
Default Fuel pump kill switch
Fuel pump cut off switch.
I'm going to add a custom fuel pump cut off toggle switch on my 07 H2. For $10 and an hour or so of work, it seems like a great added protection against someone stealing the H2.
Only issue I have before doing it, is the fuse box has to be removed in order to test which "prong" on the F/Pump relay fuse is the hot wire to the fuel pump relay when ignition is on.
Would anyone happen to have a wire diagram that I could see, which shows what color the wire is in the loom that comes from the fuse box, instead of having to pull the fuse box and risk cracking/upsetting wires underneath it.
Thanks in advance
Old Sep 25, 2023 | 07:45 PM
https://www.youtube.com/watch?v=XUhXLsrZiE0
Thanks in advance
1970's: Toggle switch
2023:
Remote Kill Switch Remote Kill Switch
Old Sep 25, 2023 | 10:02 PM
Sam!'s Avatar
I wouldn't want the Control Modules to keep resetting every morning. that is what would happen killing the battery correct?
this could create the circuit needed 70's style just not concealed completely under the fuse block, still deterrent enough for most thieves
Old Sep 26, 2023 | 08:49 AM
Install inline fuel pump relay, or use a
Wireless Relay Switch 12V,DC12V/24V/48V/72V 30A Relay, Remote Control Switch Wireless Relay Switch 12V,DC12V/24V/48V/72V 30A Relay, Remote Control Switch
Old Sep 26, 2023 | 10:48 AM
zenith's Avatar
Don't think that will work, as the fuel pump "fuse" is a relay located under the hood in the fuse block as circled in the picture.
Old Sep 26, 2023 | 01:04 PM
File Type: pdf
Old Sep 26, 2023 | 05:42 PM
zenith's Avatar
Thank you.
Old Sep 26, 2023 | 07:04 PM
Thank you.
Download entire wiring diagram and save for future!
Btw, you can "kill" switch fp relay @ the 5v power feed to energize the relay from the pcm (Dark Green/White tracer) or the 12v Gray wire to the fuel pump feed from the relay. Post results when complete.
Old Sep 27, 2023 | 10:18 PM
Sam!'s Avatar
Hey Hummerz, can you share the site or link to get this?
Old Sep 28, 2023 | 08:01 AM
PDF attached file posted above or Google search found here
