Faulty Side Red Marker Light wanted.
Old Dec 25, 2021 | 11:55 AM
oceanbrave's Avatar
Default Faulty Side Red Marker Light wanted.
Does anyone have any defective red side marker lights they no longer need?
Old Dec 25, 2021 | 12:31 PM
Old Dec 25, 2021 | 12:46 PM
WhDaFk's Avatar
Default They come in clear lenses also.
[url=http://LED Side Marker Light Kit and LED Cab Roof Smoke Lens Light Kits For 2003-2009 H2 Smoked Lens Amber/Front Red/Rear Replacement (Clear Lens Side Marker Lights) [ame]https://www.amazon.com/dp/B082GC4FCV/ref=cm_sw_r_apan_glt_fabc_FFD3RFD48WAE3SGZGC9W?psc =1][/ame]
They come in clear lenses also. WAY better replacement then OEM.
Old Dec 26, 2021 | 11:46 AM
The OEM ones are LED and for virtually everyone they lasted at a bare minimum 10+ years so I'm not sure I'd say that some chinese ones are "WAY better" than the oem ones. I've never had a generic chinese automotive led light last more than a couple of years so far (name brand stuff has). If based on appearance, then that is just opinion. Not saying its a bad opinion or anything, just saying...
Hope all had a Merry Christmas!
Old Dec 26, 2021 | 12:22 PM
"Way better" because the cheap ones are 1/10th the cost? H2 closing in on 20yrs since start of production. My 3 doesn't use rear side markers, however if I had to choose a replacement light that I don't see when I drive, I'd take a chance and keep the savings banked.
Old Dec 26, 2021 | 11:44 PM
oceanbrave's Avatar
Thanks guys, but I'm actually after a defective red side marker for analysis purposes. We don't use red in the UK so they're pretty scarce over here.
Cheers..
Old Dec 27, 2021 | 10:06 AM
Ah - I can look and see if I still have one. I've repaired them before. If I remember right the format of the diodes is a pretty standard square 4 pin 3mm dip package style that they use. You can carefully cut the back of the light open with a thin cutoff wheel on a rotary tool to get them open and then just silicone them back closed.
Old Dec 27, 2021 | 02:54 PM
oceanbrave's Avatar
..MixManSC much appreciated 👍
There must be quite a few defective ones out there.
BTW they may fail because the LEDs are being driven-hard (60ma), this is towards the top-end of their operating region, add high high ambient temperatures to that it could could stress the diode-junction.
Old Dec 27, 2021 | 05:14 PM
oceanbrave's Avatar
It's ok, managed to get a couple locally as luck would have it.
Thanks for all the support 👍
Old Dec 27, 2021 | 05:16 PM
oceanbrave's Avatar
