Driver side rear bose speaker no sound
Old Oct 15, 2019 | 12:19 PM
hnijhar's Avatar
Default Driver side rear bose speaker no sound
Hey guys I got a 2003 hummer h2 with factory bose and I don’t really play music too much now a days and I noticed my speaker in rear driver side door is not working. I checked the fader and everything is good.
The driver and passenger front work fine
The passenger rear works fine
The driver and passenger trunk speakers work fine
But the one on the back driver side door doesn’t have any sound.
Is this common for our speakers? Anything I should look for? I assume the only thing I can do is take it out and test it or swap it with the one in the passenger side rear door and see if it works
Old Oct 15, 2019 | 01:54 PM
Could be the speaker, wiring somewhere, or possibly even one of the butt connectors you used while installing did not make a good connection. Hard telling. I'd start with whatever is easiest to get at first which will be the speaker itself but that is also a risky bit as the door panels are old and brittle so you must be careful to not crack or break anything. You might break one of the retainer clips for the panel regardless though. There was a thread on here recently where someone found a source for the correct original style retainer clips for the door panels.
I've been pretty surprised as I've seen a lot of older stock speakers where the foam surround on the cone is dried out and simply gone but the stock Bose speakers, at least in my 2003, sound surprisingly very good and are all still in good condition. The stock Bose speakers in my 1999 GMC truck did not make it through the years nearly as well. lol
samer0214
Dec 17, 2019 08:07 AM
GrampaEJ
Mar 8, 2019 04:38 PM
757cc
May 16, 2014 10:37 PM
atari800
May 3, 2014 06:58 PM
gotafish
Oct 26, 2011 02:42 PM
