Door ajar message after replacing door lock actuators
Old Nov 6, 2021 | 12:51 AM
ymmotneerg's Avatar
Default Door ajar message after replacing door lock actuators
I installed new door lock actuators on drivers side front and rear doors this afternoon. All works well now.
Or so I thought... I stepped out this evening to go fill the tank and noticed the interior courtesy lights were on. When I cranked the truck and put it into gear I noticed “DRIVER DOOR AJAR” displays on dash and interior courtesy lights stay on due to the false positive of a door being open. I found some old posts on this subject but am hoping someone has some new ideas before I pull the door apart again this weekend. I’m going to check all the connections between the power window/door lock panel and the seat adjust/window panel and the new actuator of course, but if anyone has some other things to check please pass along.
Thanks!
Old Nov 7, 2021 | 06:42 PM
oceanbrave's Avatar
Prior history history will help with the diagnosis.
So a few questions:-
  • What were the reasons for changing the actuator?
  • Did you fit a "brand new" actuator?
  • Do you have the P/No's for the old one and the new one?
  • Has there been any issues with the DDM? (Driver's Door Module)
  • Were there any mechanical/electrical issues when fitting the replacement?
Looking at the wiring diagram, it appears the Drivers Door Latch Assembly connects directly to the DDM, the "Door Ajar" switch signal is the Gray/Black wire according to the circuit diagram.
I seem to recall alignment issues with the mechanism, even though there is no "free-adjustment" so it may be worth checking everything works before fully re-assembling the door.
Hopefully you will get it sorted, please keep us posted..
Old Nov 8, 2021 | 01:57 PM
ymmotneerg's Avatar
Thanks for the quick reply! Here’s what I can tell you:
  • What were the reasons for changing the actuator? - Driver side front and rear door actuators were no longer functioning. Replaced both, starting with rear. That one worked fine. Replaced the front and got drivers door ajar messages sporadically making me think I had a short or perhaps a defective actuator.
  • Did you fit a "brand new" actuator? - Yes, but turns out the replacement was defective. Got another new replacement and swapped it out this morning and so far all is well.
  • Do you have the P/No's for the old one and the new one? - Old is gone with today’s trash and new is now in door. But they are confirmed fitment. Going to send the first (defective) replacement back.
  • Has there been any issues with the DDM? (Driver's Door Module) - None thankfully.
  • Were there any mechanical/electrical issues when fitting the replacement? - None thankfully.
Looks like I had a bum replacement unit and the second one was the fix. Again, thanks for the quick response. Lots of good info on this forum!!!
Old Nov 8, 2021 | 03:47 PM
oceanbrave's Avatar
Great work and thank you for keeping this thread updated!
Seems you were unlucky to get a defective one, let's hope the replacement solved the problem permanently.
Again well done
Cobraguy
Aug 7, 2021 11:49 AM
finall
Jul 5, 2021 11:37 AM
Derek Huell
Jan 29, 2020 09:12 AM
jsbihn
Oct 22, 2016 03:16 PM
slider28
Sep 27, 2014 05:11 AM
