Crossbar Plastic Strips
A while back I found some old new stock OEM ones. I fought those things for hours trying to get them installed even after using wd-40, spray silicone lube, water, and heat. Finally gave up and threw them in the trash (very forcefully I might add) I ended up leaving them open without any real down fall. It's not like you can really see them up that high and whatever little rain that gets in them comes out the side caps. Just my 2 cents...
Yes sir. Been trying that on Google, DDG, and several other search engines. No luck so far. Just hoping someone would know the actual MFG of the cross rails (I dont think it was GM - probably a supplier like THULE) or an actual link to them. I'll keep trying the searches tho.
jdgolf
Dec 30, 2009 07:26 PM
