Code Scanner - BiDirectional - Feedback
Getting ready to replace brake lines after a rear burst and trying to get all my ducks lined up before jumping in on this. Brake lines I have and pretty much know what I am up against.
The one thing I haven't addressed yet is dealing with the ABS system after. If I follow correctly without a Tech2 to trigger ABS bleed I may get codes and/or poor braking. Not having a Code Scanner started looking around and it appears that there are options galore on Amazon for the home mechanic. Anyone have experience and recommendations for one for a 2003 Hummer H2? The two that I was looking at are Autel OBD2 Scanner MaxiCheck MX808FOXWELL BiDirectional Scan Tool NT809BTbut not sold on either and open to others that might make more sense. The above two seem very feature rich and tablet format with online updates available though I suspect not necessary if used mainly for the 2003 which I expect is fully baked out of the box w no updates to come. Around $450 each. I see cheaper ones and I suspect if my only goal is ABS I could go simpler but figure if I am jumping in might as well get something that will cover it all as I plan to have the H2 for some time.Anyway welcome any feedback. |
I will add that I almost think all of these bi-directional scanners are being sourced from a single (China) source and rebranded since they all look identical even down to the Amazon descriptions short of branding. Perhaps it doesn't really matter which one you go with. As long as it covers the H2
Old news, I posted almost 6moths ago:
Brayden Tech is the authorized American seller in North America. Listing here>>>iLink 400 Special Function (Depending on Vehicles and Model Years) Remote Keyless Entry Injector Disable Cylinder Power Balance Trans. Adaptives Reset Fuel Trim Enable Option No. 0 RPM Control Fob 1 Option 2 Fob 2 Option 1 Fob 2 Option 3 Steady State Learn TAP Option B Program Key Fobs Military or Standard Time Engine Shut Off IAC Calibration Automated Bleed Setup SDM Serial Number in BCM Idle Air Control Engine Speed Control Option A Option D VIN Information Seed and Key Relearn Reset EGR ALM Cells Program Key Fob 2 Setup New OnStar Check Mode Gauge Setup Setup SDM Serial Number in DIM Clear Cold Start Counter Tire Size Calibration EVAP Vent Solenoid AIR Pump Sol./Relay Test Fuel Injector Test 2 Fuel Injector Test 4 Fuel Injector Test 6 BCM RPO Reprogram Point of Sale Malfunction Indicator Lamp Fuel Gauge Relay High Pressure Lockoff Mixture Control Valve Spark Modifier Reset Clear Memory and Program All Fobs EVAP System Perf. Key Fob Personalization Tire Pressure Reset Afterblow PRL Update Set Language Option Configuration Chime Level Radio Setup Miscellaneous Options 1 Right Hand Drive Update HVAC Cals. in DIM Long Wave A/C Compressor Calibration Nav. Radio Theft Personalization Option Preferred System Setting Normal Chime Volume AM Pass A Stopping Theftlock LED Tuner Calibration Tuner Calibration Tire Pressure Monitor Engine Shutdown A/C Relay Loop Status Speed Cal. Reprogramming EVAP Purge Solenoid AFO Signal Enable Throttle Blade Control Throttle Actuator Control Fan Relay GEN L-Terminal Counter Reset Fast Learn Adapt. Process Program Individual Key Fob Reset Transmission Adapts. Air Fuel Ratio DRR Setup Gasoline to CNG VCIM Setup Variable Effort Steering Inclination Sensor Step 1 Alarm Siren Module Step 1 Intrusion Sensor Step 1 Twilight Sentinel DRL Option Region Code Options Disable Belt Tower DTC's Re-Zero Passenger Presence System Depressurize System Learn Lateral Accelerometer Pre-charge Bleed New Tire/Wheel Base/Booster Info. TAC Module Power Inhibit Program VIN EVAP Test Accessory Inflator Steering Pos. Sensor Calibration CD Icon Torque Sensor Calibration Next Available Slot Program Key Fob 4 DPM Setup DSCC Setup (Japan Only) Tire Pressure Warning Optional Modules Tire Rotation Procedure Injector Flow Rates Cylinder Power Balance >1500 RPM Running on Gasoline Gasoline Level Shown Relearn Window Position Electronic Suspension Control Auto. Calibration Tire Rotation/Sensor Replacement Setup IPC Zero Point Calibration Idle Spark Theft Deterrent Module Folding Top Learn Procedure Step 2 Column Lock Disable DTC(s) Audio Update Initialize Nav. Update Initialize Buckle Up Reminder Cylinder Deactivation System Cylinder 4 Cylinder 7 Injector Flow Rate Programming Preload Passenger Presence System Clutch Pedal Position Learn Radio Setup-UZ6 Setup SDM Primary Key in BCM Fuel Composition Reset Middle East Navigation Voice PC Solenoid 5 Tap Shift Oil Capacity Options Exhaust Brake Options BCM Setup Pressurize System Suspension Calibration Adjustment Clear 2-1 TAP Clear All Garage Shift TAP Clear 4-3 TAP Clear 5-4 TAP Clear 5-6 TAP Clear 3-2 TAP Key Fob Button Test Auto. Start/Stop Command Aux. Trans. Pump Relay Brake Press. Sensor 2 Learn Contactor Control Hill Hold Indicator Hybrid Batt. Discharge Amp Hrs. Hybrid Batt. SOC High SGCM Coolant Pump Relay APM set point control Recirculation Door Recirc. LED DPF Service Regeneration DPF Reset Replace Press. Sensor DPF Reset Replace Injectors Reset Injection Value - Cyl. 2 Reset Injection Value - Cyl. 4 Reset Injection Value - ECM TAC Motor Command TAC System ISC Actuator ABS Check Learn Sensor Location Instant OAT Update Cylinder 5 Reset Diagnostic Counter Capture & Restore Data Balance Rate Monitor TC Learn Exhaust Brake Control Reset Fuel Trim Link/Unlink Modules FDIM Setup Economy Mode Indicator Brake Press. Sen. Calibration Exhaust Brake Control P/N Position Learn Procedure Digital Radio Receiver Actuator Recalibration Clear Manufacturer Enable Counter Radio RPO Selection Reduction of Pressure Drive Inclination Sensor Enable Service Cleaning Procedure Reset EGR Adapts. PSCM Calibration Procedure New Actuator Setup Procedure VSCM Power Steering Reset Center I/P Speaker Left Rear Speaker Right Rear Speaker Left Front Door Speaker Left Rear Door Speaker Right Front Tweeter Clear Column Softstops Left Front Seat Speakers Left Rear Surround Speaker Rear Subwoofer Right Front Woofer Rear Console Surround Speaker Data Recorder Recalibrate Leveling Sensor EBCM Relearn Stolen Vehicle Slowdown Clear Injector 2 Injector 4 Yaw/Lateral Sensor Relearn Key Fob Battery Test Transmission Type Parking Brake Shoe Service Reset Parking Brake Calibration Noise Compensation Brazil Units (CV2) Fuel Pressure Regulator Fuel Pressure Regulator 1 Catalyst 1 Reset DPF Pressure Sensor Reset NOx Sensor 1 Reset Reductant Injector Reset Reductant System Reset Reset Clutch Overtemp Counter Brake Pedal Position Learn Reductant Fluid Tank Level Reset Reset Injection Value - Cyl. 6 Reset Injection Value - Cyl. 8 Crankshaft Position Variation Learn CKP Reluctor Wheel Learn Idle Learn Fuel Trim Reset Steering Wheel Angle Sensor Learn Distance Sensing Cruise Control Module Parking Brake Cable Replacement Setup SDM Part Number in BCM Reset History Buffer Parking Brake Actuator DTC Reset Next Available Slot Park Brake Reset PSCM Center Procedure Key Fob 2 Gear Position Sensor Learn ECM PTO Options Key Fob 4 Exhaust Gas Temperature Sensor Reset Immobilizer Key Programming Tire Pressure Sensors Learn NOx Catalyst Reset Brake Booster Vacuum Relay Brake Pressure Sensor Calibration NOx Sensor 1 Reset Fuel Pressure Regulator 2 Yaw Rate Sensor Reset Reductant Fluid Tank Level Reset DPF/ Catalyst 2 Reset Power Steering Softstops Learn Reductant System Data Reset NOx Catalyst Reset Steering Wheel Angle Sensor Reset Total Fuel Consumed Reset NOx Sensor 2 Reset Clear Driver Window Learned Values Cylinder 2 Injector Flow Identifier Reductant System Data Reset Clear Left Rear Window Learned Values Cylinder 4 Injector Flow Identifier Passenger Presence Sensor Learn Read LIN Bus Device ID Information Cylinder 2 Fuel Injector Correction Value Reset Range Actuator Learn CAN Bus Configuration Learn Cylinder 4 Fuel Injector Correction Value Reset Hourmeter Reset HVAC Actuators Learn Fuel Injector Correction Value Preset Reset Injection Value - Cyl. 5 APP Learn Cylinder 6 Injector Flow Identifier Reset Injection Value - Cyl. 7 MAF Sensor Learn Cylinder 8 Injector Flow Identifier NOx Cat. Reductant Loading Reset Fuel Rail Pressure Sensor or Fuel Rail Learn DC Charging Disabled Reset Clutch Pedal Position Learn Glow Plug Control Module Reset Hybrid/EV Battery Contactor Open Reasons Reset HO2S Learn Remote Vehicle Start Disable History Reset Content Theft - Exterior Lamp Flash Engine Oil Life Reset Clear Transmission Counters Panic Alarm Transmission Adaptive Pressure Reset Clutch Purge Digital Radio Receiver Control Module Configure New Module Transmission Learn Ambient Air Temperature Calculation Reset Erase All Key Fobs Automatic Electric Door Locks (AU4) Without Seat Belt Pretensioner (-A70) Copy Injector Flow Identifiers from Glow Plug Control Module to ECM Key Fob 1 Electric Door Locks (AU3) Without Seat Belt Pretensioner (-A70) Cylinder 5 Fuel Injector Correction Value Reset Key Fob 3 Enable Deployment Loops Cylinder 7 Fuel Injector Correction Value Reset Tire Type/Pressure Selection Battery Sensor Module Learn Reset PTO Inhibit and Disengage History Transmission Adaptive Values Learn Clear Disable History Neutral Position Sensor Learn Yaw Rate Sensor Learn HO2S Heater Learn Charge/Assist Gauge Power Steering Softstops Reset Liftgate Maximum Open Position Learn Engine Clnt. Pump Relay Steering Wheel Angle Sensor Centering Gear Selector -N- Position Learn Hybrid Batt. Charge Hrs. Brake Pedal Position Sensor Learn Average Fuel Age Reset Hybrid Batt. SOC Low Clear Passenger Window Learned Values Hybrid/EV Battery Pack Coolant Control Solenoid Valve Learn Hybrid Disable Clear Right Rear Window Learned Values Passenger Compartment Heater Coolant Control Solenoid Valve Learn Starter Enable Passenger Presence Sensor Learn Hybrid/EV Battery Pack Data Reset APM Mode High to Low Remote Vehicle Speed Limiting Reset Fuel Composition Reset ABS Relay HVAC Afterblow Configuration Module Setup Recalibrate All Motors Exhaust Gas Temperature Sensor Learn Copy Tire Pressure Monitoring Information DPF Reset Replace ECM EGR Valve Learn Idle Speed Adjustment DPF Reset Replace DPF Turbocharger Learn Crankshaft Position Reluctor Wheel Learn Reset Injection Value - Cyl. 1 Injector Flow Rate Programming Intake Air Flow Valve Learn Reset Injection Value - Cyl. 3 Headlamp Leveling Sensor Learn Front Suspension Position Sensor Trim Height Reset Injection Value - All Cyl. Clutch Position Learn Control Module Reset Idle Speed Control Depressurize System Transfer Case Clutch Identifier Learn IMT Valve Adapts. Automatic Electric Door Locks (AU4) With Seat Belt Pretensioner (A70) DPF Pressure Sensor Learn Prog ISU with RKE only (w/o Immo) Electric Door Locks (AU3) With Seat Belt Pretensioner (A70) DPF Service Regeneration ISC System Manual Door Locks (-AU3) (-AU4) Idle Speed Control Reset Brake Valve Cycling Park Brake Calibration CO Adjust Learn Sen Loc with Tire Press Tool Adjustable Pedals Softstops Learn Rear Drive Clutch Service Calibration Setup Cylinder 3 Vehicle Direction Camera Learn Fuel Pressure Regulator Fast Learn Special Functions Clutch Control Module/Rear Drive System Matching Identification Setup High Pressure Fuel Pump Learn Column Calibration Frontview Camera Learn DPF Pressure Sensor Reset Supply Pump Learn Learned Values Reset Cylinder 2 Injector Fuel Transfer Pump Electronic Brake Control Module Learn Cylinder 4 Injector Trans. Oil Overtemp Lamp Hybrid/EV Battery Pack Capacity Learn Adaptive Pressure Control Learn Exhaust Brake Cut Fuel Economy Reset Cylinder Deactivation Exhaust Flow Valve Learn System Configuration Hybrid/EV Battery Pack Capacity Reset Erase/Program All Key Fobs Reset Code Index Key Fob 6 Calibrate Module Reset Key Fob 8 Hood Ajar Indicator Range Actuator Learn Vehicle Model Setup New ROS Suspension Position Sensor Trim Height Rear Differential Clutch Service Calibration Setup Power Window Motor Programming Flywheel Learn Speedometer Calibration Steering Pos./Torque Sensor Cal. Rear Suspension Position Sensor Trim Height Exhaust Aftertreatment Data Reset Active Vacuum Booster Erase Valet Mode Code Fuel Filter Life Reset Assist Step Learn Procedure Long Range Radar Sensor Module Learn NOx Catalyst Reductant Loading Reset Fuel Pump Trim Reset Transfer Case Clutch Overtemperature Counter Reset NOx Sensor 2 Reset TV Region Lockout DPF Reset Reductant Injector Reset Learn Tire Pressure Sensors Catalyst Reset Reductant System Reset Steering Position Sensor Centering ECM Reset Cylinder 1 Injector Flow Identifier Throttle Sweep AWD Disabled-by-Malfunction Counter Reset Cylinder 3 Injector Flow Identifier Actuator Removal Procedure Fuel Pressure Regulator Learn Cylinder 1 Fuel Injector Correction Value Reset Acceleration Sensor Reset Intake Manifold Runner Control Valve Learn Cylinder 3 Fuel Injector Correction Value Reset Active Antenna Boost Pressure Sensor Learn All Cylinders Fuel Injector Correction Value Reset Left Front Speaker Cylinder 1 Injector Cylinder 5 Injector Flow Identifier Right Front Speaker Cylinder 3 Injector Cylinder 7 Injector Flow Identifier Subwoofer Fuel Injector Learn Transmission Solenoid Valves Calibration Preset Left Front Tweeter Exhaust Flow Control Valve Learn EV Range Reset Right Front Door Speaker Info Display/Infotainment Faceplate Reset Add/Replace Key Fobs Right Rear Door Speaker Key Fob 5 Content Theft - Horn Chirp / Door Key Cylinder Disarming Parental Password Key Fob 7 Ambient Air Temperature Instant Update Left Front Woofer LH Drvr. Personalization Personalization Rear Center Surround Speaker Export ID Engine Serial Number Right Front Seat Speakers Universal Theft Deterrent Copy Injector Flow Identifiers from ECM to Glow Plow Control Module Right Rear Surround Speaker Japan Key Fob Option Cylinder 6 Fuel Injector Correction Value Reset Unlock Radio Setup SDM Part Number in DIM Cylinder 8 Fuel Injector Correction Value Reset Setup New PIDM AIR Pump PTO Operation Mode BMC Prim. Piston Pos. Relearn Loud Amp Chime Volume Idle Air Control Reset DMCM Coolant Pump Relay Normal Amp Chime Volume Special Function Injector 1 FM Pass A Stopping Trans. Oil Life Reset Injector 3 Country Code Fuel Pump Misfire Graphic Valet Lockout IAC Circuit Test Security Telltale Idle Learn Reset Fuel Trim Reset Navigation Option Tire Pressure Monitor DTC Fuel Injector Balance Yaw Rate Sensor Recalibration PTO Options Oil Life Reset APP Learn EGR Solenoid Option No. 1 Reset ECM Aux. Cooling Fan Fob 1 Option 3 SCLM Setup Setup New HVAC Fob 2 Option 2 Step 1 AIR Pump Relay Option No. 2 TPM Learn Mode Fuel Pressure Control Shift Column Unlock Reset Learned Values Fuel Injector Modification Setup SDM Part Number in IPM Setup New SDM Option E Bluetooth Cruise Enable Dolby N. R. Fuel Filter Life Reset New BCM Setup Time Set Spare Tire Monitoring Disable Wait to Drive Lamp IAC Reset Cylinder 1 Program All Key Fobs Crankshaft Pos. Variation Learn Cylinder 6 Bleed MPA Automated Test Pilot Injector Balance Procedure Reset Transmission Oil Life Export Option Elevated Idle Setting EVAP Service Bay Test ECM/Immobilizer Relearn HO2S Heater Learn CNG to Gasoline IPC Recalibration Radio Setup-U85 Mileage Log Reset Option C Copy and Paste TPM Information Secondary Ckt. Evacuation Synchronize IPC and SIR Afterblow Option Headlamp Type Option Key Fob Function Test North America Intrusion Sensor Step 2 TDC Learn Disable/Enable Secure Car Inclination Sensor Step 2 Program Key Fob 1 AIR Service Bay Test Alarm Siren Module Step 2 Program Both Key Fobs TV Region Select Front Fog Lamp Type BCM Reprogramming Pilot Injector Stop Perimeter Lighting Language Cruise Control Options Traffic Seek VIN Relearn Gear Down Protection Options Vehicle Speed Limit Setup New VTD Module Fob Button Hold Time Setup SDM Serial Number in IPC New VIN Suspension Position Calibration Calibrate Trim Height EVAP Purge Solenoid (PWM) Clear 1-2 TAP ABS Motor EVAP System Seal Clear 2-3 TAP Recalibration Fuel Injector Test 1 Clear 3-4 TAP Fuel Injector Flow Test Fuel Injector Test 3 Clear 4-5 TAP Reset TPS Learn Value Fuel Injector Test 5 Clear All TAP Cells BPP Sensor Calibration Throttle Position Preset All TAP Cells Automatic/Manual HVAC Options TIM Reset Clear 6-5 TAP Cassette Icon Fuel Mode Indicator Lamp BCM Copy and Flash IAC Motor Position Fuel Gauge Aux. Trans. Pump Steering Tuning Selection NGO Enable Batt. End of Life Est. Reset Invalidate All Fobs Low Pressure Lockoff Steering Angle Sensor Centering Program Key Fob 3 Forced Fuel Switch Over IPC Setup Setup New RCDLR Add/Replace Key Fobs Loud Chime Volume Factory Reset Throttle Position Valve Twilight Sentinel Reprogram Vehicle Type EVAP Purge/Seal Miscellaneous Options 2 TPM Option Enable Setup SDM Part Number in BCM Reset Battery Total Ahrs. Dimming Delay English/Metric Status Reset Idle Learn Sensor Learn Mode Enable Acquisition Setting Adjustable Pedal Calibration Cylinder Power Balance <1400 RPM Program Phone Number Tire Type/Pressure Selection Setup SDM Part Number in IPC Setup RFA CNG Level Shown |
Wow.I think that covers it!
Those are still more expensive than a clone Tech2 and will still not have access to or the ability to do some things that a Tech2 can. Rear air suspension (which you might not have or care about) as an example. I'm not aware of any other tool that can access that module other than the actual GM tools.
The nice thing on those others though is they can be very helpful with other brands of vehicles as well. |
Tech 2 is King
MixmanSC is right on. When you look at the big picture, Cost, Ability to diagnose, Being able to program modules and apply software updates, IMO nothing beats the Tech 2 platform, about the only drawback I can think of its only good for GM vehicles up to 2013 and many people do not want to buy a dedicated tool for a specific vehicle or brand. Mute point for me when I consider what I have invested in my H2. Not only that if it saves me 1 trip to the dealership its paid for itself! (BTW we are speaking of a Chinese clone)
