Brake fluid leak at pedal $$$
The gift that keeps on giving. This trucks starting to show its age. The fancy ass 08/09 only $1000 brake booster/master combo that has no documentation and no one knows anything about is slowly dripping into the cabin.
I was checking if my column was still tight after adjusting the screws and half of me wants to say “I didn’t see anything” but the other half knows better. Especially with no functioning e-brake. Are there rebuild/seal kits for this available anywhere? Or am I throwing another grand into the bottomless orange hole? |
Look at it this way, 25% of car loans are over $1000 per month. You toss a $1000 every now & then into a 15 year old+ vehicle and this problem most likely not happen for another 15 years +/- .... PLUS you do not have the "bottom less hole" of spending a $1000 a month on a vehicle that is probably depreciating that each month. For the most part H2's are going to at least hold there value at current prices (if maintained and not rusted to hell). So, look at the positives- You still have a unique vehicle people comment on..... that or have the $1000 +/- monthly payment with the same GMC, Chevy truck you see at every other stop light...... Myself, I will take the $1000 maintenance issues once a year +/-. Bite the bullet & get it behind you. Its done and most likely will not happen again a long time from now...
So I noticed the exact same thing on my 08 a few nights ago while looking for the backup camera wire. I went with the "I didn't see anything", but now that you've mentioned it, I guess I can no longer say anything. Mine is also a bottomless orange hole, as it's waiting for new oil cooler, trans cooler, and oil pan gaskets to come in to be replaced.
TASCA seems to have the whole assembly or just the master cylinder
https://www.tascaparts.com/oem-parts...inder-19258789 |
Just replied to another thread hoping to find some good information, but that member also didn't have any luck :(
https://www.hummerforums.com/forum/h...27/ |
Originally Posted by Chrmer3
(Post 404815)
Originally Posted by HellHoof
(Post 404819)
(Post 404822)
yah maybe it matches up internally to some 25$ autozone special.
Originally Posted by Gavin Costigan
(Post 404830)
Thanks. This is the route I’m going to go. $500 for a master cylinder is still an absolute rip off. I’ll take apart my old one once it’s off and see if I can match up some parts for everyone else with the issue. There’s no way the internals don’t exist somewhere.
I’m changing from “I didn’t see that” to “I’m waiting on Gavin” |
