bad ignition switch?
Old Jul 4, 2020 | 03:38 PM
yellabummer's Avatar
Default bad ignition switch?
i know about this bulletin, and i have all the transmission codes, keys getting stuck bc i cant get it in park. ive checked fuses, seems to be getting voltage but im also having other issues like im having to pump up my brakes on start up and my air suspension compressor is not coming on anymore. anybody have any ideas. i have a 2005 h2 sut.
Old Jul 4, 2020 | 05:00 PM
For safety reasons, the pcm needs to verify the transmission is in PARK, without that, you could take the key out of the ignition, depending on the grade you park on, it could roll into a building or end up in the middle of the street.
Old Jul 4, 2020 | 06:41 PM
i mean i finally got it in park and the key out, just naming one of the symptoms to see if anyone has had the same issues. i guess I'll just replace the ignition switch, just wondering does the air ride suspension circuit go through the ignition switch? and abs? bc i havent heard about this situation with other faulty ignition switchs
Old Jul 4, 2020 | 07:23 PM
Post an update after you replace the ignition switch.
Old Jul 6, 2020 | 03:13 PM
madmayo's Avatar
Have you tried popping your coffee holders out of the Center console and taken a look at the neutral switch on the shift solenoid. The connector is fixed to the gear shifter and the harness moves with it. All my wires broke clean off the connector. I was stuck in park. Maybe your wires are hanging on by a strand. Just something to try.
Old Jul 9, 2020 | 09:37 AM
yes i checked them. i ended up replacing the ignition switch and im no longer throwing codes. seems to have fixed it, now im just chasing down a random misfire lol
bureau13
Dec 22, 2019 10:25 AM
BLUETHUNDER
May 1, 2010 07:23 PM
HammerDown
Aug 21, 2007 06:41 PM
