Back Up Light Socket - Problem
Old Mar 4, 2025 | 11:59 AM
Jack America's Avatar
Unhappy Back Up Light Socket - Problem
Hey all,
I'm pretty sure my passenger side back up light socket needs to be replaced. I cannot find one that is a two-tap pigtail that accommodates the 3156 bulb for my 2005 Hummer h2.
If anyone knows where to get these sockets, let me know
Note, bulb works, socket meters perfectly when put in reverse, but bulb will not light up whether it is a new bulb or old.
I tried added wires to the connector, then attaching them to the bulb, no bueno.
I think there is a short within the socket that created a direct connection therefore bypassing the bulb.
Old Mar 8, 2025 | 09:20 PM
RobertDez's Avatar
You might have to replace the whole housing. There's several aftermarket options out there. Amazon carries them.
Old Mar 8, 2025 | 09:22 PM
RobertDez's Avatar
Recently put these on my 2003 as mine were leaking really bad. Quality is actually better than stock.
ACANII -For 2003-2009 Hummer H2 SUV Black Housing Tail Lights Rear Brake Lamps Assembly Pair Set Replacement Left+Right https://a.co/d/1pFHbEF
Old Mar 8, 2025 | 09:24 PM
RobertDez's Avatar
Ahhh ..... Just realized you need the sockets. I would bet it probably uses the same bulb sockets as the Tahoe.
Old Mar 9, 2025 | 08:53 AM
legerwn's Avatar
was looking around and GM doesn't do a good job with their diagrams in the parts lookup department
it does show the harness plug and the socket as two separate parts, have you taken yours apart and verified if so?
I'm surprised they use a 3157 dual element bulb for the reverse light, not sure why they would.
Neal
Old Mar 9, 2025 | 09:22 AM
RobertDez's Avatar
This should work for you:
3156/3157 Pre-Wired Harness Pigtail Socket Connector Plug Install LED Bulbs, Fit for Most Chevrolet Silverado GMC Sierra for Brake/Tail Lights Turn Signal Light, 4 PCS https://a.co/d/iDlatjt
Old Mar 9, 2025 | 09:25 AM
RobertDez's Avatar
.... And I think the reason for the reverse light having three wires.... Ever notice when you unlock the vehicle, the backup lights also light up? Just a guess.
I would bet that most auto parts stores carry the GM sockets you need....
Old Mar 11, 2025 | 10:30 AM
You are right it is the 3156 bulb. My mistake.
Old Mar 11, 2025 | 10:38 AM
I found a used wiring harness on Ebay that was tested to work. It came with the complete harness, all sockets and even bulbs.
Everything is good once again.
Old Mar 12, 2025 | 04:36 PM
Mark R's Avatar
I hear Parts stories like that all the time.... It's either eBay or Amazon that saves the day. Since I am into Electronics Repair on Vintage Audio gear, there are no new parts available. First stop is eBay....Second Is Google who will direct you to somebody or somewhere. Then... If not a Custom part it's Amazon.
You have to wonder..How did we survive in the 60's 70's 80's and halfway thru the 90's till the internet grew and all this crazy parts hunt started.
Oh.. I forgot Youtube..LMAO.... Like How to catch a mole in your lawn..LMAO
dvine
Nov 10, 2020 09:59 AM
2005H2
Nov 17, 2016 09:01 PM
nijoma
Dec 17, 2013 07:54 PM
amrg
Feb 25, 2013 04:42 AM
vernrose
Oct 11, 2009 02:32 PM
