Any ideas
Old Oct 1, 2020 | 05:28 PM
Tim Nowicki's Avatar
Default Any ideas
Any ideas?
i was bypassing the factory amp and a speaker wire touched a hot wire now no sound. Head unit is fine?
Old Oct 1, 2020 | 08:08 PM
Blackbus's Avatar
Is the amp bypassed? Or did you stop bypassing when you saw sparks? If you still are still on the amp check the amp fuse. If you just bypassed the amp to the head unit there may not be enough power for the head unit to power the speakers without an amp.
Old Oct 1, 2020 | 08:30 PM
Speakers can take a hot wire without an issue, unless connected too long, then you may see smoke. Check your fuses.
Old Oct 1, 2020 | 09:56 PM
it was bypassed and playing through the speakers as I was tying in the last speaker is when it happened. I bench test the head unit with other speakers without issue. What else is running through the down stream harness after the amp???
thanks for any help.
Old Oct 2, 2020 | 12:11 PM
then if the radio tested fine you will now have to pull a panel off and test at the speaker locations with your test speaker.
Old Oct 2, 2020 | 05:37 PM
Thanks I’ll be doing a full wire chase this weekend.
Old Oct 3, 2020 | 11:02 AM
tharber's Avatar
Check the 30amp fuse under the hood its labeled amp I think and might have a back door power supply to head unit.
Tim
Old Oct 3, 2020 | 11:36 AM
Default Confused
Went head unit directly to speaker wires still no sound. Do the speaker wires go through the sub? If so is the sub fused?
Old Oct 3, 2020 | 12:16 PM
no i think the amp controls the sub. maybe the amp is in protect mode. pull its fuse and see if it resets. if you cant pull the fuse i guess disconnect the battery
Old Oct 5, 2020 | 01:04 PM
Seems like some confusion. To be clear, bypassing the factory head unit or bypassing the factory amp? I'm assuming amp since you specifically stated "bypassing the factory amp" and one does not bypass a head unit, they replace it. In any case somewhere on these forums is a thread on the factory stereo systems that has the full factory wiring diagrams, pinouts, etc for both types of factory systems. Just going to have to search some to hunt it down. Could be very helpful though.
