Any Advice For Pulling The NAV/Radio From My 2009 H2?
Was just wondering since I'm pulling out the Climate Control Module to Change the faceplate, I thought I'd pull the NAV/Radio out ad hose down the connectors and sockets with DeOxit D-5 which is a contact enhancer. This is in response to the NAV screen going black a few times. Right now it's been working fine for a few months. Like they say ..."Don't fix it if it ain't broke" But while I'm in there I thought I'd give it a shot.
My question is..should I be concerned about disconnecting power and pulling the Radio fuse? With the key out of the ignition nothing should be energized with the exception of a small amount of power feeding the unit for the Clock and power up circuit. Any special precautions I should take? Your Thoughts? |
I've pulled mine multiple times with the battery connected and key off, never an issue.
Neal |
If you disconnect the battery cable your good to go, this is the safest route, also, interesting you said the screen went dark, did the whole radio shutdown or was it simply the display, if it was the whole radio I might believe your plan on cleaning and spraying the connector might help, if it was strickly the display that checked out I don't think cleaning the radio connectors will do much for you. I had a similar problem with my 06 and it turned out to be a cable going to the LCD display internal to the radio.
Originally Posted by H2-SUT
(Post 392683)
This could also be weather and temperature induced. Like I said...It's been working fine now for a few months. I might just pass on pulling it out for now. Here's a Video of a NAV/Radio which looks the same as the 2009 H2.. You can see as it it's taken apart that behind the screen is the main video board. Note the amount of ribbon connectors..Could be where the problem is. Anyway..might be a project for warmer weather or the next time it blacks out. |
Originally Posted by legerwn
(Post 392682)
Neal |
