Airbags won't come back on after lift kit install.
Old Aug 27, 2018 | 03:26 PM
Mr. Demeanor's Avatar
Default Airbags won't come back on after lift kit install.
My 2005 Hummer H2 SUT is in the shop getting a 6" Fabtech lift installed.
the truck is ready except the airbags will not re-inflate. This is the kit that retains the airbag system. The sensors we're relocated using the parts and instructions provided by Fabtech.
If I recall from when I replaced the airbags there was a reset that had to be done but I can't find or recall what I did.
Any help appreciated.
Old Aug 27, 2018 | 03:30 PM
Old Aug 28, 2018 | 10:29 AM
You may check the fuses in the event it ran so much to blow one and prevent the compressor from burning up.
disclaimer: Not an H2 owner.
Old Aug 28, 2018 | 10:57 AM
Having a Tech2 would greatly simplify figuring that out as you can manually command them to deflate, inflate, re-calibrate their height, etc. Sounds like a fuse is blown or something or maybe something got unplugged when working on the rear suspension.
Old Aug 28, 2018 | 02:21 PM
I called Fabtech myself and they said if the installer left the battery connected when moving the sensors it likely sent so many faults to the ECM it needs a hard reset with the proper scan tool. Im guess thats what happened. Still waiting to hear back from the shop.
Iluminati
May 18, 2015 04:24 PM
nick_bp
Aug 21, 2013 09:39 PM
sa24
Feb 22, 2013 02:21 PM
quadblaster240
Nov 29, 2010 06:29 PM
ador
Jan 18, 2010 11:17 AM
