Air suspension issue
Old Nov 23, 2024 | 03:34 PM
Greekman64's Avatar
Default Air suspension issue
My 05 Hummer H2 started showing suspension service message. Brought to my mechanic and he suggested i take it to GM dealer. GM says they do not work on vehicles over 10 yrs old. Issue is have is randomly the suspension will not inflate. It may work fine for 4 days and then it will not inflate. I changed both 60A and 15A fuse and relay in engine without any change. Any suggestions? Thanks
Old Nov 23, 2024 | 06:28 PM
oceanbrave's Avatar
@Greekman64
Retrieving the diagnostic trouble code history may save some time and effort👍
Old Dec 23, 2024 | 06:15 PM
bcester's Avatar
If all your fuses check out including the hidden one under the hood by the driver side frame (front tire) check out, next thing to look at would be the compressor/faulty wiring.
When the bags are low do you ever hear the compressor kick on? First thing it should do is self level at startup with the driver door shut. Just a thought.
Dave Gan Ja
Apr 15, 2025 11:43 AM
MiBo
Nov 5, 2018 03:42 PM
0Hummer3H2
Oct 29, 2012 11:18 AM
jdhornbeck
Dec 28, 2010 11:35 AM
rotten
May 30, 2010 06:59 PM
