Ac actuators
Hello everyone. I have a 04 h2 and none of my actuators are working. The mode actuator was working when I bought the h2 but when I tried the calibration on them it stopped working as well. I have checked continuity on every actuator wire everything is showing good. There is a brown wire going to each actuator called (ignition 3 voltage) but when I check the voltage on it it's showing around 12 volts. Could that be the problem? Also I have tried another cheap actuator with no luck and a different control module but still no luck. Any help or advice will be appreciated.
Welcome to HF. I MOVED this from the New Member Section which, as it says, is only for introductions and not Tech Questions.
All H2 Tech Question go in the H2 section..... crazy right? :D You will get some help here from the H2 people. |
The wiring diagram shows the following common connections:-
Actuator Pin 9's are the 0V -> 5V door position signals which tell the HVAC where that actuator is . Normally there would be a DTC set, possibly B0229, B0414, B00424, B3770 (Actuator Range Performance) or B0263, B0268, B0408 or B0418 (HVAC Door Actuator Circuit) Presumably you've tried recalibrating them ? If all the voltages look OK it could be the HVAC module itself. Not you can remove the HVAC without dismantling the entire center console. Hope this helps, please let us know how you get on 👍 |
How to recalibrate the actuators?
Never actually done it, but here's the info I found:-
Actuator Recalibration When replacing the HVAC control module it will be necessary to allow the HVAC control module to perform a calibration process. When installing the HVAC control module be sure to perform the following: Important: Do not adjust any controls on the HVAC control module while the HVAC control module is self-calibrating. If interrupted, improper HVAC performance will result. Place the ignition switch to the OFF position. Disconnect the scan tool. Install the HVAC control module. Connect all previously disconnected components. Place the ignition switch in the RUN position. Wait 40 seconds for the HVAC control module to self-calibrate. Verify that no DTCs have set as current DTCs. When replacing a HVAC actuator it will be necessary to allow the HVAC control module to perform a calibration process. When installing the HVAC actuator be sure to perform one of the following: Important: Do not adjust any controls on the HVAC control module while the HVAC control module is self-calibrating. If interrupted, improper HVAC performance will result. Preferred Method (w/ Scan Tool) Clear all DTCs. Place the ignition switch in the OFF position. Install the HVAC actuator. Connect all previously disconnected components. Place the ignition switch in the RUN position. With the scan tool, initiate the Motor Re-calibration feature of the Heating and Air Conditioning Special Functions menu. Verify that no DTCs have set as current DTCs. Important: Do not adjust any controls on the HVAC control module while the HVAC control module is self-calibrating. If interrupted, improper HVAC performance will result. Alternate Method (w/o Scan Tool) Clear all DTCs. Place the ignition switch to the OFF position. Install the HVAC actuator. Connect all previously disconnected components. Remove the HVAC B fuse for a minimum of 10 seconds. Install the HVAC B fuse. Place the ignition switch in the RUN position. Wait 40 seconds for the HVAC control module to self-calibrate. Verify that no DTCs have set as current DTCs. |
