9.5 lbs Warn winch strong enough for an H2?
Old Feb 4, 2014 | 06:21 AM
franzu666's Avatar
Default 9.5 lbs Warn winch strong enough for an H2?
Hello all,
Warn claims they designed their winch model 69502 9.5xp specially for the H2. (it's embedded into a special bumper they also provide).
Do you think 9500 lbs towing capacity is enough for an H2? Apparently It's below the minimum towing capacity generally advised of 1.5 X GVW.
Thanks for your advises,
All the best
Old Feb 7, 2014 | 04:22 PM
Kirkhayes37's Avatar
I did an Engo 10k. I am guessing it is better than no winch.
Old Feb 7, 2014 | 11:59 PM
Your H2 weighs approximately 6000#. The Warn 9500# cradle winch was the winch sold at Hummer dealerships for the H2. A good 9500# winch should be fine.
Old Feb 9, 2014 | 12:58 AM
franzu666's Avatar
Great! I feel reassured now.
Old Apr 17, 2014 | 10:31 PM
United Timber's Avatar
You can always use a ****** block (pulley) to double the pulling power.
Old Apr 20, 2014 | 12:43 AM
The base rule of thumb is 1.5 times the loaded weight of your rig. With a curb weight of 6,614 lbs empty and loaded up for wheeling more like over 7,000 lbs. That would be 7,000 + 3,500 = 10,500 lbs or larger. You can't go wrong going lager on a winch!
qui
Jan 26, 2014 05:36 PM
Brady
Dec 29, 2008 12:41 AM
kdec19
Dec 11, 2007 01:24 PM
importkiller
16
Sep 6, 2007 08:09 AM
RickLF
Aug 23, 2007 09:19 PM
