9.5 lbs Warn winch strong enough for an H2?
Hello all,
Warn claims they designed their winch model 69502 9.5xp specially for the H2. (it's embedded into a special bumper they also provide).
Do you think 9500 lbs towing capacity is enough for an H2? Apparently It's below the minimum towing capacity generally advised of 1.5 X GVW.
Thanks for your advises,
All the best
All the best
The base rule of thumb is 1.5 times the loaded weight of your rig. With a curb weight of 6,614 lbs empty and loaded up for wheeling more like over 7,000 lbs. That would be 7,000 + 3,500 = 10,500 lbs or larger. You can't go wrong going lager on a winch!
qui
Jan 26, 2014 05:36 PM
RickLF
Aug 23, 2007 09:19 PM
