2008 Interior Upgrade
Old Jan 13, 2008 | 09:30 AM
sitevestors's Avatar
Default 2008 Interior Upgrade
Just purchased an '03 H2 but want to install the 2008's interior. Has anyone in here ever attempted this? Should be able to complete for a few thousand especially since I found an entire seat set from a wrecker. Also, how hard is it to mount the spare on the back of the truck instead of the stock interior mount? If anyone has any install tips please let me know.
Old Jan 13, 2008 | 11:14 AM
Default RE: 2008 Interior Upgrade
Rear bumper mount spare tire carrier isn't hard to do and frees up the back of the Hummer. Well worth the cost/effort. No idea on swapping out the interior IMO not worth the cost/effort.
Old Jan 13, 2008 | 03:12 PM
GorillaH2's Avatar
just design a whole new interior while you are at it......seriously redesign the interior out of fiberglass and you can do some sick custom stuff
Old Jan 13, 2008 | 10:35 PM
Yeah, I think it would be almost IMPOSSIBLE to install the 08 interior unless you buy EVERY PIECE from the dealer or website. That's ALOT of pieces and ALOT of CA$H!!!
Old Jan 13, 2008 | 10:38 PM
vilim12's Avatar
definetly shouldve bought the 08.....
Old Jan 14, 2008 | 12:31 PM
TRUBRIT's Avatar
If you want the actual 08 interior then that will include all the new Dash which is going to be pricy. If you just want the two tone look of the 08, then go Katzkin. If you go Custom upholterer, then one Front seat will cost you around $550.00 to reupholster in Black leather, including material.
Old May 20, 2011 | 07:05 PM
jcm3900's Avatar
Default swap out interrior
i have a 04 hummer and i want to install the 08 hummer insides i already have done the door panels but i had to cut the dash for the doors to close. i am looking for an 08 hummer dash if anyone has one .
Old May 23, 2011 | 10:37 AM
Hummer Guy's Avatar
This was a major update - and it isn't as simple as plug-and-play parts..
The seats, for one, have a completely different bolt pattern...
Old May 23, 2011 | 10:42 AM
Indy's Avatar
Why not cover the interior with leather...probably cheaper than swapping out for an 08 and will be more exclusive. Good luck with your interior upgrade. I never minded the more utilitarian plastic interior myself....easy to clean and it is a HUMMER in the end. Cheers, Indy.
Old May 23, 2011 | 04:55 PM
No more Jeeps's Avatar
Cheaper to buy a 2008. A interior swap will cost big $$$ and really add no value.
